FOR SALE
R32 coupe boot hinges and springs $50 (do disassemble for freight)
Complete R32 silver door, with glass window reg etc paint ok but has some scuffs light scratches $100
Greddy oil cap, suit all RB motors, premium oil cap does not get seized tight, lightweight alloy and in immaculate condition, oil seal is perfect also $80
Rb26 gearbox crossmember $50
R32 overflow bottle $20
Rb26 transfer shaft $50
GTR (r32, r33, r34) clutch master cylinder $40 excellent condition from a spec r33 gtr
R32 drivers door switch $50, perfect condition, all switches work
R32 gtr/gtst dash pad suits all r32 models decent condition has gauge mounts fitted $50
Located Gold Coast
Will freight auswide
Johnny 0414596256
Edited by slidinr32gtr
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
