Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
I would have agreed with that (Ben) as well, thats how I always set my timing before - pfc commander always shows 15 degrees hot idle - I set it at 20 (on harmonic balancer) now cos thats what it used to drive like before and thats where the bolts on cas / my marker was. Before taking it off.
Could be my timing gun is off or actual cam timing belt has skipped >> screwdriver test thru sparkplug hole with engine at TDC. Faaark do I have to take off fan and rad again (to turn engine manually). So hard to get to fan bolts.
Edited by rondofj
No you can get to the crank pulley bolt from underneath the shroud
Maybe you should take the top timing cover off and put the crank on tdc mark and take a photo of where your cam pulleys are at
  • Like 1
Yep what Ben and gtsboy say.... This is what I originally said a few pages back when I was looking through a log.
It's been said multiple times by multiple people!
Ron, are you using a lead or the wire loop that never works correctly method with your timing gun?
lead to no1 plug that works correctly of course
So to clarify.
A plug lead in between no 1 coil and plug. As in remove the coil and put a plug lead onto it, then plug that onto the plug?
Doesn't mean it doesn't exist. Just not adjustable perhaps.
However I do remember there's a 2D table water temp (static) vs. Ignition trim.
By default all the values are 0 on FC Edit.
This is why I mentioned half a dozen times you need a data logit kit to make sense of this
So to clarify.
yeh exactly, dont see how else it could be done - and the gun goes off that in-between lead
How so interesting ?
That pic is how it should be done if the pickup at the rear is no good
Which is most of the time
Why don't you just get a proper mechanic to check you cam timing and set the base timing
I'm sure Unigroup wouldn't charge you more than $100 to set it and check it
As it has already took you how long and to set it and still it's not right
$100 is worth the less headache and unreliable grenade engine if it's taken on the track and pinging hard
Wow just did this- timing gun straight off no1 coil wire (no in-between leads) and it shows 15 on both harmonic balancer AND PFC commander! Disconnect TPS and it shows 21 on PFC AND harmonic balancer. No
f#%^king around with the CAS or anything. I had set it dead correct back then.
Running straight off coil wire is easier but not stable it shows timing then goes blank, shows timing then blank every 3-4 secs. With in-between lead its rock steady timing displayed.
Thats it no more stuffing around with timing, it was proper after all.post-49401-14102552872501_thumb.jpgpost-49401-14102553065654_thumb.jpg
Edited by rondofj
I just open the slide on the pickup and hold it against the back of No1 coil :yes:
I find it odd that you want the best possible o2 sensor mounted as close as possible to the engine, but set the timing using that method that seems pretty half arsed. Have you compared it to using a lead in between?
Thats it no more stuffing around with timing, it was proper after all.attachicon.gifImageUploadedBySAU Community1410255281.384884.jpgattachicon.gifImageUploadedBySAU Community1410255302.376683.jpg
What do you mean straight off the wire?
What XKLABA said. The gun connected straight onto no1 coil wire/lead that comes from loom. Coil still sitting directly on plug, no in-between lead
Edited by rondofj
Lol, yeah bit weird, have tried it and tested that method over 10 year ago when setting the cam gears on the 32, there is no manual timing adjustment on the 34, Ross trigger wheel, I mathematically worked out what the timing mark on the 34 was which was then checked by Scott to be spot on and the rest is done by the Syvecs
I want the O2 where I want it because it will send its signal directly to the Syvecs and not to a gauge on the dash, and the closer I can get it to the engine the sooner the ECU will get an idea of what is happening in the engine, and yes I know how long it will take for the gas to move 1m down the exhaust and don't care, an engine spinning at 7000rpm does a lot in that time
Plus I have two ports filled with O2 sensors not getting used so may as well use them
The sensors I have ordered are NTK LZA09-E1s which are OEM sensors for the hypo Hondas which is what the Syvecs is pre programmed for
Um no, hold it against the white bit on the side of the coil oppersite the plug, the pick up will pick up the coil firing
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
