Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Ok will try that out, now Im kinda getting why the ABS shouldnt work, because ABS and TCS rely on the same wheel sensors n I've broken that circuit by pulling the TCS fuse? Best be I remove that TCS butterfly and put that fuse back in
Edited by rondofj
They literally have the same ECU as mentioned above.
I'd be checking ABS, mainly cause TC was your issue, and you didn't have (either!) TC light on. So maybe your ABS light is also mysteriously on.
Would have been interesting to see if this whole thread would have happened if the light bulbs were in the dash to begin with, hehe.
Leave the sensors and stuff connected, just remove the plate. When when you can confirm everything is working right, everything is where you need it to be, and you know what's going on with it all... then pull the light out :P
With all this talk of ABS, when I think of it there have been numerous instances during on/startup when all the lights go on, my ABS light takes 1-2,3 seconds longer to go out than the others. TCS/SLIP/HICAS lights never been on at all.
And weird that pulling fuse out doesnt trigger engine light, how would someone know if their fuse is blown n systems not working?
Does anyone know if its possible to just pull off the J Pipe (one that houses the stock BOV) and remove the TCS butterfly with the throttlebody still bolted on? I cant even see the bottom 2 throttlebody bolts with that ugly TCS motor in the way lol
Don't think you could. But you might as well try.
An extension and a socket gets the bottom 2 throttle body bolts very easily.
Took the f$$ker off and the TCS fuse back in- easy 30min job, no need to take off throttle body, just unscrew TCS butterfly from the front after taking off that annoying J pipe. So no TCS butterfly interrupting my performance now due to faulty TCS ECU/wheel sensor? and ABS system now re-enabled with the fuse back in.
The TCS butterfly centre stem has a slot through its middle as you can see, will this impact performance?
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
