Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Ok will try that out, now Im kinda getting why the ABS shouldnt work, because ABS and TCS rely on the same wheel sensors n I've broken that circuit by pulling the TCS fuse? Best be I remove that TCS butterfly and put that fuse back in
Edited by rondofj
They literally have the same ECU as mentioned above.
I'd be checking ABS, mainly cause TC was your issue, and you didn't have (either!) TC light on. So maybe your ABS light is also mysteriously on.
Would have been interesting to see if this whole thread would have happened if the light bulbs were in the dash to begin with, hehe.
Leave the sensors and stuff connected, just remove the plate. When when you can confirm everything is working right, everything is where you need it to be, and you know what's going on with it all... then pull the light out :P
With all this talk of ABS, when I think of it there have been numerous instances during on/startup when all the lights go on, my ABS light takes 1-2,3 seconds longer to go out than the others. TCS/SLIP/HICAS lights never been on at all.
And weird that pulling fuse out doesnt trigger engine light, how would someone know if their fuse is blown n systems not working?
Does anyone know if its possible to just pull off the J Pipe (one that houses the stock BOV) and remove the TCS butterfly with the throttlebody still bolted on? I cant even see the bottom 2 throttlebody bolts with that ugly TCS motor in the way lol
Don't think you could. But you might as well try.
An extension and a socket gets the bottom 2 throttle body bolts very easily.
Took the f$$ker off and the TCS fuse back in- easy 30min job, no need to take off throttle body, just unscrew TCS butterfly from the front after taking off that annoying J pipe. So no TCS butterfly interrupting my performance now due to faulty TCS ECU/wheel sensor? and ABS system now re-enabled with the fuse back in.
The TCS butterfly centre stem has a slot through its middle as you can see, will this impact performance?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
