Hi Guys,
I recently moved from SA and I need to find a tuner that is trustworthy and in particular; knowledgeable with Nistune (RB20 ECU running a RB25DET, EPROM program/new features etc.) E85 etc.
I live in Springfield and work near Beenleigh. Willing to travel to get the best result.
Thanks in advance.
https://www.sau.com.au/forums/topic/446499-best-nistunee85-tuner-in-seq/
I currently am running 100% E85. But I'm thinking it would be more convenient to go flex in the near future. The United Race Blend E85 is another curveball (which will depend on price and them not running out all the time).
My car has been tuned without VCT. So the first thing I need is a tuner to tweak the tune with VCT on and then I can set the window switch at the optimal cross over. It's so doughy down low as you can imagine.
To compound matters my exhaust manifold is slightly cracked. So I’ll probably get a 6boost (high mount) so new pipe work and maybe turbo? Waste gate? The list goes on and never stops ;)
Got my R32 gtr with nistune done on E85 at EFI, they seem to have done a great job and the car runs well. So plus 1 for EFI I guess.
The 107 octane race fuel variant from united seems interesting, though I don't think i'd go for it as it'd limit the areas you could refuel way to much for a street car I think. Also because i'm getting valve float and I wouldn't really gain much more top end with it.
That being said, would be great for more dedicated track cars, or in a flex setup if you were content to spend a lot of your time on 98.
What switch do you have for VCT with RB20 ECU? Something external or a tweak?
If you want a good starting point then turn VCT on at 1200rpm and off at 4800rpm. It might not be perfect but will be much better than what you have and probably a bees dick off optimal.
  • 8 months later...
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
