The evo club are having their own happy laps at LP and are looking for some cars to fill some spaces.
This is NOT an SAU event.
Description: Here is a chance to get out on track for a fun cruise and have some om nom noms! Bit of spirited driving is allowed but it is still an event on a race track so a few rules need to be followed (see below). Normally breakfast is served with bacon, sausages, tomato, eggs, beans, toast, cereal, tea & coffee (instant).
Time: 7:00 AM Arrival 7:30 AM Breakfast 8:00 AM On Track (These are rough times & will depend on track staff on the day)
Cost: $35 per person (Driver & Passengers)
Payment Details: Name: Carl J Hendle BSB: 064172 Account Number: 00636521
Requirements: 1. Participants must meet minimum age requirements for being on track. QR have a minimum age of 12 for passengers.
2. No overtaking in the first 2 laps.
3. The overtaking car is responsible for completing the overtaking move safely.
4. Overtaking is only permitted on straights, unless clearly waved passed by the car in front.
5. Overtaking move must be completed well before the end of the straight, and the car being overtaken must be given plenty of room.
6. Cars should not be more than 2 abreast at any point on the track.
7. Be aware of cars around you, in front and behind (and beside when being overtaken, use your mirrors).
8. Do not assume that the car in front of you knows you are there.
9. Pre pay is essential unless other wise arranged with myself, no EFTPOS is available.
Lakeside Specific Rules:
10. No overtaking or cars side by side on the kink.
11. There is to be no racing
12. The straights are speed limited to 120km/h
13. Any car that goes off the track will be pulled off the track & their session ended
14. There is not to be more than 1 sec of tyre smoke.
15. There are to be no helmets
16. Vehicles must have current registration and number plates are not to be obscured in anyway
17. All roll cages must be 100% legal & mod plated. They must also be fully padded. Any car with a roll cage must be inspected before being permitted on track. There must also be NO REAR PASSENGERS IN ANY CAR WITH A ROLL CAGE.
Attending:
https://www.sau.com.au/forums/topic/446600-qeo-lp-happy-laps-16-08-14/
have paid for me plus 1 passenger,thought it only right to attend as they have helped us out with numbers several times so just returning the favor,i hope im not the only one attending,but if i am i will chop as many ernies as i can,lol. :domokun::domokun::domokun:
  • Like 1
Haven't you got rid of the 595 SS's yet? I'm pretty it took tony less time to change his wheel bearing than what its taken you to get new tyres.
No need to get rid of them yet, they're still legal and are perfectly fine for daily work.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
