Hello
As I build up my r32 gts-t, I am learning things.
I will now see what it is like to drive with a boost controller on the car. Later a turbo upgrade.
Wondering, if later I want more power, is it better to put a rb 25 engine in the car and upgrade? Put a rb26 in the car and upgrade? Or just save money for a while and get a r32 gtr? Will the features on the GTR be worth it or will putting a bigger engine in be better and more cost effective and sensible?
I have researched what the engines can do, just wondering what would be the most sensible route.
https://www.sau.com.au/forums/topic/446825-changing-engines-or-changing-cars/
The real smart option is sell the un-built-up yet car and buy someone else's finished project car then change the styling/bits to suit what your end goal is.
This saves you monstrous amounts of time and money in the long run.
Are you in Japan or Aus? You can buy already modified GTR quite cheap in Japan. But for example in NZ you can get a well modified R32 GTR for $30 - $35K or buy a stock one for $20k and then have to spend $30k to get the same thing.
A few points.
No-one in their right mind would put an RB26 into an R32 when a Neo RB25 is a better motor.
No-one in their right mind would put an RB30 block based engine into an R32 unless they like bonnet clearance problems and doing stupid things like lowering the subframe to make it fit.
R32 GTR will send you mad and broke unless you spend a lot of coin to buy a really good one. Anything that is old and much used will always be breaking something annoying and expensive to replace. Better off buying an R34 GTR.
A few points.
A few points.
I live in Japan
Early model r32 gtr getting expensive because can be imported back to the states legally now. 91, 92's and 93's are still ok.
Why is the RB25 neo a better option? I reseached putting Rb25's in(non neo) and it seems to be difficult because of the wiring and so on.
R34 GTR still close to 30000 dollars here.
I like the idea of the ITB on the 26.
Edited by yoshiii335
Neo 25 is basically the same capacity as RB26, has variable cam timing. Has the same type of solid lifters as RB26, same oil pump, same conrods. Made same power (officially, actually less in reality) as RB26 when new. But the actual power potential of the base engine is about the same as RB26 - just with variable cam timing on top to make it nicer to drive on the street.
it is a no-brainer.
And if the wiring work required to fit a 25 of any sort is too much trouble, then the work required to fit an RB26 will be too much also.
ITBs are nice, but in real terms you woul dnever know the difference whether they were there or not.
R34 @ $30000 sounds like the way I would spend my money.
  • Like 1
it is a no-brainer.
Ok I will look into it more,
R34 is nice but there are other more important things to spend 30000 dollars on than a r34 gtr at this point.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
