Hi all. I'm floating an idea I've been thinking about for some time now. Forgive me if it's been discussed before, but if we get enough interested and serious people together we can make a weekend of this!
Most of you probably read about these so-called "Supercars" in the big published magazines as much as I do. The accepted acceleration performance measurements used to be 0-100klm/h and standing 400metres. As cars get faster, these seem less often used, and standing kilometre, 0-200klm/h, and 0-300klm/h times/speeds are more common.
Before I go too far with it, some questions!
1) How many of you would be seriously interested in comparing the performance of your car against the likes of F1 Mclaren, Enzo, etc, under controlled conditions?
2) How much would you expect the entry fee to be?
3) How far would you travel to be involved?
4) How many attempts would you expect to get your best times?
5) If outrageous insurance costs didn't allow owner/drivers, would you allow a professional driver to drive in your place?
If enough serious interest is gauged, I'll take it to the next step!
:) Ben.
https://www.sau.com.au/forums/topic/44684-speed-trials-0-300klmh-tests/
  • Replies 41
Hey there.
In order to do these tests, you would need a very very long piece of road.
The Wheels PCOTY tests are done at Avalon starting from the taxiing lanes and floored from there.
It would be more a case of finding the right bit of blacktop than anything else.
BASS OUT
Hey there.
BASS OUT
Of coarse these are all considerations. Of coarse you need a car CAPABLE of 300klm/h! There aren't that many around!
I would suggest that maybe (this is just a thought) that entry would require an official quarter mile time slip of 12.5 sec or better?("Supercar" class)? This would at least give the car a chance of completing the tests in the available room.
:D
I actually have some clips of skylines in japan doing this test. Its absolutely amazing. The veilside R32 GTR gets to 300km/h in 13.72 seconds and thats even with a mistake changing from 2nd to 3rd gear!!! :uh-huh: . I got them from www.exvitermini.com quiet a while ago. Not sure whether they are still on the site but its worth a look!
wow this is a great idea, but i cant see it working with all the crazy laws/regulations/insurance/hooning laws etc in place
I would attend, im fairly sure anyone whos ever been to Autosalon/Drag Combat/Jamboree... would attend if you advertised it good
HKS have an entry on that site. Dunno if it were their drag car or not, but it ran the 0-300 in 17.64 seconds. Now their drag car runs 181mph, which is 289kmh in 7.67 seconds.
why isn't this thing leading the fastest times 0 - 300kmh by 4 or so seconds? Surely a change of gear ratio wouldnt be too difficult and have them take another trophy to their name??
last i heard this car now does 0-300 in 13.0 :)
I would travel within capital city to use it
I would pay about $150 per run, although my car is limited to 230km/h
I would not let someone else drive it unless it was a dyno
Would only expect one run as it is not a tuning run it would put a huge stress on the car
I'd be interested if someone wants to organise it....
Dave, I am already in the process of orgainising a day for later this year with Kev and Scott from Driver Dynamics at Avalon. You were already going to be coming. We have just got a couple of technical hitches that have to be ironed out.
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
