Hey All, just before i purchase one, anyone have any stories/advice on 2nd hand Power FCs, or any ECU for that matter. I figure that if you are going to get it retuned anyway, there is not much point buying a brand new one? THe only advantage i can think of is the warranty, but are they really prone to failure anyway?
comments/advice?
Cheers,
Matt
https://www.sau.com.au/forums/topic/44695-used-power-fcs/
Well i bought a used Power FC about 18 months ago from Japan, and guess what it didnt work.
There were two possible reasons why it was no good. One was that it had been locked with the Exel software, so couldnt be tuned...the other was it was simply cactus. Thankfully the importer who i bought it thru refunded my deposit.
2nd time round (about 1 week ago) i just bought a new one, as demand is so good they often fetch near new money even when used.
But others have said, no moving parts, but they are still an electonic item that dont like shock, moisture and heat so still pays to be wary to test before you buy a used one.
https://www.sau.com.au/forums/topic/44695-used-power-fcs/#findComment-913308
Hi oofoofoo, I bought (on the Skylines Downunder Forum) a used R32 GTST Power FC 2 years ago, no problems. Had it checked with a Datalogit software as I had heard about other R32 GTST ECU's coming with locked maps, mine was OK. I have since bought a Commander (on the Skylines Australia Forum) and my own Datalogit system (direct). Works great, highly recommended. :D
https://www.sau.com.au/forums/topic/44695-used-power-fcs/#findComment-913357
Absolutely no reason not to buy a second hand one (taking the usual precautions, obviously). However, I have been monitoring the prices on Yahoo JP pretty closely the last two months and, as Roy alluded too, the prices they fetch -- even in Japan -- is very close if not higher (by the time you include auction fees, agent fees and shipping) than to get a new one from Nengun/Greenline (~$1200 to your door with hand controller).
If anyone as a good deal on a used PFC (+ hand controller) for a R32 GT-R, let me know :D
Lucien.
https://www.sau.com.au/forums/topic/44695-used-power-fcs/#findComment-913484
be careful as i believe in the past some models of the power fc dont work with various versions of the hand controller. i believe it boots to the apexi logo and sits there and does nothing else, i think the main cause is incorrect ecu vs hand controller version
could be the only downfall i guess
https://www.sau.com.au/forums/topic/44695-used-power-fcs/#findComment-913605
thanks all, for responses. I am getting one at a pretty good price so ill make sure i get some assurances of its tune-ability. As for hand controllers, looking at this site suggests that all the commanders made for nissans should be interchangable, just not other car brands. (ie they are all 415-X001s)
http://www.ooparts-international.co.jp/ind...r_fc/index.html
https://www.sau.com.au/forums/topic/44695-used-power-fcs/#findComment-913628
JaFF: $1240 (w/ hand controller) is about the right price. Aussie dollar is pretty crappy at the moment so prices are slowly rising as places order new stock.
oofoofoo: $850 for just a PFC, second hand, is more than I would pay since they are about $900-950 new last time I checked. For $100 I would rather the warranty..?
Lucien.
https://www.sau.com.au/forums/topic/44695-used-power-fcs/#findComment-914781
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
