Hi.... if u guys remember me, i got tru with the L20ET its running quite fine! But i have a new problem, i need to get a L24E wiring diagram i can't find 1....and i also need to kno if the L28E wiring is the same as the L24E if not, whats different? and can i use the L20ET loom and ECU for the L24E and add in what extra wires after...i do have an L20ET wiring diagram (3 plug style) i know the L24E ECU connector is 1 long jack tho... so can someone please help me!!!!! Thanks!
https://www.sau.com.au/forums/topic/447246-l24e-wiring/
  • 3 months later...
Brandy,
If your going to put all the turbo bits off your L20ET onto an L24E, just use the same ECU and all will be good, but an L28ET ECU would be better, but if your trying to make your L20ET into n/a you need a new ECU L24E or L28E.
If you still need wiring diagrams I can probably copy them for you.
Cheers,
Dennis
https://www.sau.com.au/forums/topic/447246-l24e-wiring/#findComment-7441450
