The oil only drips through it, doesn't get pumped in there like some people think, you can always tell the bottom oil drain as its the only major difference between all the other fittings, so the top one is oil in (opposite to oil drain) then yeah water return is supposed to sit slightly higher than water in.
https://www.sau.com.au/forums/topic/448086-help-again/#findComment-7378831
What? Are you serious?
It is pumped through it. How else would the oil get there? Ball bearing turbos need less flow than bush bearings, but certainly way more than being dripped on....
There's a guideline on how much flow, and I can't remember it, it its not measures in drips!
  • Like 1
https://www.sau.com.au/forums/topic/448086-help-again/#findComment-7378859
The smaller oil inlet then outlet is only to stop the oil building up pressure in the core. There should be a flow of oil but having the return bigger then the inlet should ensure that the flow is never restricted causing pressure.
  • Like 1
https://www.sau.com.au/forums/topic/448086-help-again/#findComment-7378870
Maybe I wasn't clear with what I meant to say - It doesn't flow through it at 50psi "as some ill experienced people have thought. Of corse it has a flow rate or how else would it move through the turbo?
But thanks for the serious reply.
https://www.sau.com.au/forums/topic/448086-help-again/#findComment-7378882
Pressure is indirectly proportional to flow
To the OP, I'm guessing you were talking about the cylinder shaped object between the oil inlet and the line? It looks like it might contain a mesh filter to me, but the easiest thing to do would be to pull it off the other fitting and have a look. If it has a mesh filter inside it should come apart for cleaning. If its a one way/check valve (and I'm not real sure why you would put one there) then you can test that by blowing through both ends.
If its a restrictor, and it seems WAY over the top for that, you should be able to blow through it but feel quite alot of restriction. In my head theres no way its a restrictor, there are much more discreet/compact ways to do this
https://www.sau.com.au/forums/topic/448086-help-again/#findComment-7379473
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
