Basically my sisters car has a cracked head. Will be taking the head off to get it fixed and wondering what parts need to be or should be replaced while the heads off. Going to do valve stem seals, head gasket (obviously) manifold gaskets. What else should be done?
The engine has 140,000k's on it and is still running great.
Also the radiator is screwed... anyone suggest what all alloy radiators are available for around 800dollar mark to suit r32 gts-t?
Thanks
Jamie
PWR do a straight fit alloy rad. for these -- around $770 for a 40mm one
inlet gaskets, if your doing valve stem seals and head gasket, just go buy a VRS kit from nissan for them.... they are cheaper than getting the bits separately!! that will do cam seals, inlet and exhaust gaskets, head gasket andvalve stem seals.. pretty much everything you need!
your fixing the head? why not replacement? minimum of decking the head would be needed too!
so all i will need is a VRS kit and manifold (exh+inlet) gaskets?
Metal head gaskets will make the car a little slower off boost won't it and make it a slight bit laggier?
sprint32, true but i just have a thing against using thing if they have failed that much to actually cracking! personal choice though!
Cyph3r, the VRS kit includes the inlet and exhaust gaskets, it has pretty much all top end gaskets you would need!!!
metal head gaskets (when larger than standard) will reduce the compression, so if everything else remains the same then it will perform worse, usually they are used with increased boost!
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
