Hey guys,
Recently picked up a 2001 250t RX four Stag. Got her cheap, but inherently with a few issues. Having a few problems sourcing an oil leak! If anyone has any ideas it would be an amazing help!
It isn't a big enough leak to lose too much oil and never drips on the ground. It does, however drip directly onto something hot as it smokes up the engine bay and smells of oil. It seems to be coming from the turbo side of the engine. What I have worked out, is that it only seems to leak under load - It could sit and idle forever and not leak, but take her around the block and she stinks!
I have recently replaced both rocker cover gaskets (as they were rock solid and pissing oil everywhere) and I had hoped this was the cause. Unfortunately not.
Any help/guesses/suggestions would be amazing guys!
Also, upon replacing rocker cover gaskets - what a pain in the ass that was (backyard mechanic over here lol), she now seems to miss upon acceleration. At idle, smooth as, revving in park smooth as but as soon as i drive it feels like its bogging down/missing. I have checked all vacuum lines and connectors and I have put back everything seemingly correctly. (most things will only fit in one spot!). Im stumped! Maybe I should study mechanics so I dont have these problems hahah! :( All learning I suppose!
Any advice greatly appreciated! Cant wait to get this badboy on the road!
Corey
https://www.sau.com.au/forums/topic/448400-vq25det-help/
Hey mate, thanks for the reply! Ah I had that problem initially but its in 100% now! No leaks at all from rocker cover. I'm thinking might be old oil stuck between heat shield and exhaust still burning off...
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7384951
Hey Daleo havnt had a chance to take her for a solid spin yet to doubje check the oil leak. :( still got the running rough problem tho, cant work it out!! Ive noticed there us a random miss/murmor at idle too but very infrequently...arrgh
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7386575
Could be crank or cam sensors, it can be hard to fault find these without a consult reader and a few spare parts... I assume the plugs have been changed?
If you still have an oil leak and it still smells after a drive, there are a few other things to check, the cam sensor Orings can leak, and the dipstick can blow oil out if it isn't in properly, or the seal is damaged. Both these will cause oil to burn on the manifold.
  • Like 1
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7386649
I didn't change the plugs, however it ran perfectly fine before?
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7388907
I would have at least checked one while I was in there, otherwise you may need to do the whole job again just to change the plugs.
Can you remove one and check the gap?
I did check one, seemed worn but I didn't have the time to get a set soi just put it all back. I assumed it ran fine before so? Ehhh :(
Engine light has now decided to come on, maybe that's a good sign as I can get it scanned...
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7390482
Hey Scotty,
Oil smell cleared up - seems it was just some old oil on the exhaust :)
As for the rough running - don't know how i didn't spot this before, but found this badboy snapped off today!
https://drive.google.com/file/d/0B2Y9a42ue_rIa04ybDFYU203N2F1aWxmMlpOdnZ0dzQ4Z1Jz/edit?usp=sharing
(Sorry, couldn't work out how to wack a pic on here)
The snapped off bit comes from a line that hits a t-piece then goes off to what looks like somewhere near the turbo, and the other way goes to the piping from the intercooler close to the throttle body. The small line you can see goes to the piping just after the airbox. Obviously the line was just hanging loose and i didn't notice! Could this be why shes running terribly?
Cheers :)
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7392742
I doubt it. It would have just been running high boost (14psi) all the time.
Did you get it scanned yet?
Did you unplug any coils while you worked on it? I have seen the plugs for them mixed up more times than I can remember.
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7392746
Ahh, wasnt even sure what that sensor was for!!
I did unplug some. I thought if I had put one in wrong, it would miss terribly even at idle? It seemed pretty obvious which was which as the length and position of the cables went to the right place. But maybe not. I feel like an idiot haha! :(
Ill kick myself when I work out what dumb mistake I have made!
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7392750
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
