It's a n/a rb30 series 2 block and it's an RB30DET now. I bought a half done motor and pretty much have pulled everything apart over months and rebuilding it. I figured I'd bugger off the bulky heat transfer and add an oil cooler and remote mount. This was the first time I removed it.
Someone added the heat transfer block then. I'm pretty sure the thing they destroyed in the process(your photo) is the oil filter bypass valve (used when the filter is blocked to bypass it)
I would pay carefully attention and see if you need to block it up or else you might be bypassing the oil filter now.
Fairly certain my old 30 blocks had this filter by-pass valve.
It's a steel ball and spring style which when operating, simply by-passes the filter.
Yours would be doing this all the time.
I think I can see the remains of the spring in one of the photos, also not good.
Definitely needs attention.
If you're doing a rebuild, you need to remove all gallery plugs, strip/clean/flush anything to do with oil supply.
Don't trust any work done by a previous owner, as this clearly shows.
It might not be all doom and gloom though. I think if you look into it the heat exchanger has the bypass valve in it, which is perhaps why the original owner hacked it out of the block.
You "might" be able to just put the heat exchanger back on, but the piece of spring sitting there is concerning and will need to be dealt with. It's also an indication of the previous owners workmanship which is a shame.
The previous owner was a bell end. I bought the rb 25/30 all excited then I got home after the 2 hour drive and found rust and leaves all through it. I have removed the head and rebuilt based on these shonky findings.
I think I might try tapping a thread through the shit and screwing a bolt in there. I won't run the relief valve.
Edited by negativecamber
Fair enough. There's no real need to actually run the valve..its only there incase the filter gets so blocked it can't flow oil, which I'm sure you would never let it get that bad before servicing the car.
The only thing is to make sure you get rid of all of the swarf caused by tapping it.
I'll vacuum the hell out of it and I currently have the sump off so I'll make sure no dwarf gets anywhere. I had a similar experience with installing a rear head drain the other week.
It's a track only drift car so it will have regular fluid/filter changes.
Thanks for your help guys.
I've been changing oil filters for at least 50 years and I've never come across a spin-on that doesn't incorporate a by-pass valve.
Owners should understand the by-pass will open when the filter medium becomes blocked and also on cold start when oil is at its max viscosity.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
