I recently bought a GReddy full auto turbo timer and harness off them,and was very pleased with the service.Helpfull and quick responces.
I can't comment on the intercoolers,but if they say they are genuine hybrid,then they probably are.
Hope this helps :thumbsup:
Although I didnt complete my purchase with them due to time constraints, I was very impressed with the extra effort Zac put in trying to locate some apexi parts for me.
Zac went to extraordinary lengths to contact me during some email problems to ensure I was happy and kept informed.
Excellent service.
  • 6 months later...
Currently getting some nice bits through Zac at the moment!
Z32 AFMS x2
Apexi FC and controller
GTR R34 OEM rims and tyres
the guy has the patience of a saint :D as it is not easy to work your way through the yahoo japan site for the first time....
great feedback, and is very very helpful! I couldn't speak higher about the operation!
so if anyone is even considering getting some parts do yourself and your bank balance a favour and go through him!
http://www.slidewizeimports.com
to give you guys an idea, Im looking at 4k for all that gear!!!!!
i have to say had no problems with slidewize at all, got a set of odd sized P1 racing rims and a safc all delivered on time in A1 condition... first place i ask if looking... cheers Zac big thumbs up
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
