Bump.
Mates having the exact same problem with his pull clutch. Looking for internet help before I have to pull the box out myself :P
It will grind all gears, but will eventually go into gear.
Engagement is all the way to the floor.
Brand new single plate clutch with flywheel.
Master and slave were never separated.
Made a 4mm spacer for the slave to get full travel and it still won't fully disengage.
This seems to be a pretty common problem, with no resolve.
So I went from an RB25DET Neo bottom end to a RB30E bottom end. Gearbox/clutch/slave/master were all the same components.
Turns out that the crank in RB30's must be lost than RB25 as what was happening was the sleeve over the input shaft (the thing the throw out bearing sits on) was pushing on the centre of the clutch disk and pushing it into the Flywheel, providing drive even when the clutch was disengage.
So the clutch fork was moving fine, the pressure plate was being released no problems, but because the clutch disk was bent pressed against the Flywheel it was like it wasn't working.
So I got a small Dremel and cut about 5mm off the end of that shaft, put the box in and never had any more issues.
Thanks for the reply. Interesting and funny it was just enough not to work, but bolt on fine.
I think there may be a problem with the throwout bearing on this one. As there is a clip collar (circlip) that the fork bearing slips into and it is meant to hold them together? I haven't seen a gtr one before.
My theory is, if the circlip is damaged the fork bearing will grab a little and then pull through.
  • 1 month later...
Sorry to re bump
 V
but i think im having the exact same problem. Did a crankshaft swap in my motor. Bolted it all in and together but cant select gears when its running.
Had the box back out, rechecked clutch, fork, bearing etc and all were good. Put back in and no good.
When you say 'cut 5mm off the end of that shaft' what shaft are you referring to? The crankshaft? Input shaft?
If you could describe it a bit more that would be great.
You need to measure from the block to the throw out bearing face , and on the gearbox side from the belhousimg block mating surface to the throw out bearing and figure out what is going on.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
