hey guys I got a rb30 patrol with fuel injection im wondering what mods are required to get it to 180rwkw
the turbo I was going to use was going to be a t04e
will I need to lower my compression
also if I want lower compression can I just put in turbo pistons or do I need to change rods also
thanks guys
https://www.sau.com.au/forums/topic/449359-rb30-patrol/
Steve200b, have you got a dyno sheet to prove that?
I find it very hard to believe 160atwkw on 35's and a GQ drive line, and through a VL/r31 afm?
My GQ with a RB30DET @15psi just made 185atwkw on 33's and 4.88:1 diffs, pfc, 400cc inj and z32.
https://www.sau.com.au/forums/topic/449359-rb30-patrol/#findComment-7405026
thanks guys
this isnt the 90's any more
just to clarify, t04e's are junk, and you dont need to lower your compression or open your engine to turbo an RB30e
best way to do it would be to wire in a cheap ecu like an adaptronic or something, hang a highflow hypergear off the side with all the supporting systems and then a decent tune
https://www.sau.com.au/forums/topic/449359-rb30-patrol/#findComment-7405316
Would you care to share the physical basis behind that claim? Where does the power go?
Well think of it like this, take out the small drive shaft, the r200 diff center, the little irs axles.
Put in a truck tail shaft @ twice the wieght, fit a 10.5" size diff center, fit axles twice the size and tires that each wiegh more than 2 of your original tire/rim combos together and tell me that wont sap hp?
Its very basic physics, E=mc2.
sounds stupid but its the more mass you try to accelerate, the energy required increases massively!
the next one is newtons laws of motion, every body acted upon by a force has a equal and opposite force acted back upon it, so the requirement to accelerate it is more so the heavier the object.
So this is where hp goes, through frictional loss, witch is a combination of windage, physical wieght, drag- from both wieght, size of components and material density.
It goes on and on the deeper you look into it!
The lhc in Europe uses maga watts of magnetic power to accelerate bits of particles to near light speed, if mass was easy to accelerate, theyd be sending house bricks around the tube wouldn't they?!!!!!
Edited by nicksamaniac
https://www.sau.com.au/forums/topic/449359-rb30-patrol/#findComment-7405451
Not true at all. Well, except perhaps the LHC bit.
There is SOME inertial effect from having heavier tailshaft, heavier gears, heavier axles etc. But it is very important to realise, especially with respect to the tailshaft and the axles, that the polar moment of inertia of those items is pretty bloody small, given that most of the mass is very close to the axis of rotation. Wheels, sure, they have a much higher polar moment of inertia, so making them larger and heavier will certainly increase their inertial effect on acceleration.
BUT, and this is a really big BUT, power output can be measured at a steady state. Acceleration only plays a part if you're running a ramp. So, if you were to take your engine, put it on an engine dyno and get the true power output of the engine, then install it into a car with skinny tailshaft etc and run it up to peak power and hold it there for say, 5 seconds, you should get almost exactly the same power reading as if you did the same thing with a bigger tailshaft, axles, etc.
You cannot argue against that. It is the absolute truth.
The single largest difference in power readings between engine dyno and chassis dyno in the power lost at the interface between the tyres and the rollers. Ignore hub dynos for the moment, because they throw a spanner in the works. We'll come back to them later.. Think about it. You have a 500HP engine in a car on a chassis dyno. You expect to lose 25-30% of that power when measuring it at the wheels, right? Where does that power go? I will tell you, it is most certainly not lost in the drivetrain. Some of it is, for sure. But if you think you can lose 125HP into the oil of the gearbox and the diff without that oil boiling in just a few seconds then you are severely mistaken. Furthermore, the amount of power lost through the drivetrain is probably not even a constant fraction anyway. There is almost certainly a minimum amount lost whenever the drivetrain is turning at speed, regardless of load, and there is probably a rapidly diminishing increase with load. This means that it starts at a non-zero number and increases with load but with the amount lost as load increases becoming a smaller and smaller fraction of the additional load.
Have you ever watched a seriously powerful car on a dyno pull? Ever noticed how much smoke and rubber dust is generated at the rollers? Ever wondered why you get higher readings if you strap the car down harder? It's because there is slip between the tyre and the roller. You lose a LOT of energy there. And the tyre and the roller are spinning around at very high speed in the air so they at least have some convective mechanism to shed that heat. The gearbox and the diff housing have almost no air flowing over them at all and so have almost no convective cooling. So if the 500Hp engine loses 125HP + on a chassis dyno, then I would say that more than 80% of that loss is at the rollers and only maybe 20% is in the drivetrain. So if you then beef up any part of the drivetrain so that it chews up more power, let's say you make it chew up 50% more than it used to - you are only increasing the measured loss at the treads from 125 HP to 137HP. Or, looking at the real drivetrain loss on its own, from 25 to 37 HP. Either way, it's not as damaging as you might have thought. But here's the best thing. Thicker tailshafts and axles and so on don't even have that effect. They don't lose any more power. They simply don't. They will certainly take a little off the acceleration because of added inertia, but as I explained above, that effect will be small.
The big wheels will certainly dull acceleration.....but again, they don't actually "lose" power. Measured at steady state (and ignoring compound/grip differences in whatever tyres you may have on different sized wheels) the power should be very close to the same.
Edited by GTSBoy
https://www.sau.com.au/forums/topic/449359-rb30-patrol/#findComment-7405511
Good argument, I still disagree with some of what youve said, most power runs I see have a ramp rate at witch power is measuered, nobody does a static power measurement at full rpm, full hp and full torque for 5 seconds!
Thats just stupid.
inertial wieght is ONLY low nearer the center of the shaft as it approaches zero rpm at the center even if surface speed is 100's of meter sec.
The only way id believe component size and wieght make no difference to hp output is at a static speed, but thats when load drops, torque becomes static and power drops off to a point where its only maintaining vehicle speed.
In any other scenario wieght WILL be a loss on the system.
If you take that 500hp engine and match it to a standard Nissan FS5R30A 5sp box, on the output in 4th (1:1) it makes, say? 490hp (for argument sake)
Now take that same engine, match it to a 15speed road-ranger transmission and same 1:1ish ratio, how much does it make now?
It can ONLY make the same at a static speed, BUT more torque will be required, more load will be applied and more hp will be needed to maintain the same static speed.
https://www.sau.com.au/forums/topic/449359-rb30-patrol/#findComment-7405571
And as a real world example, I took my patrol in stock trim for a power run so I had a starting point before all my engine mods.
It made a massive 75.3hp at the wheels on 28" tires, witch are like little chees cutter wheels.
the dyno operator said it was an expected result for the car type and showed me results from VL and r31 runs.
(same engine on a different drive line)
All of these figures where over 90hp, so how does a no loss idea explain a loss of 15hp?
And he also said it'll be lower due to, you guessed it, a bigger drive train!
https://www.sau.com.au/forums/topic/449359-rb30-patrol/#findComment-7405577
Yes they are, I can also confirm how crap they are, all companies make shitty choices, that is one Nissan made! Take a good solid engine and put a stone age fuel delivery system and ignition on it!
but mine was running efi.
https://www.sau.com.au/forums/topic/449359-rb30-patrol/#findComment-7405594
Yes, well. That's the difference between real power and measured power now, isn't it? Just because the dyno induces an error (ie, because of including inertial effects), doesn't mean that any power is actually lost in its journey from one end of a tailshaft to the other.
https://www.sau.com.au/forums/topic/449359-rb30-patrol/#findComment-7405624
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
