As per the topic i am considering buying this used hks gt-rs turbo for my s15. I have bought a few used turbos before but i just thought i would ask here for some more opinions, I am mostly concerned about the amount of corroision and the colour of the exhaust wheel and wastegate flap. Does it look like its had a hard life? I have the money to buy a new Gt2871R but this used turbo is less than half the price and i wouldnt mind saving the money if it looks ok.
Thanks guys
https://www.sau.com.au/forums/topic/449502-does-this-used-turbo-look-ok-to-buy/
Apparently the turbo has no shaft play and no marks on any of the compressor/exhaust wheel fins or inside the housings they run in.
I'm mostly concerned about the colour of the exhaust wheel and really and havent been able to find much info on it. The turbos ive bought in the past have had black sooty exhaust wheels. the only other turbo i have at home in one i changed on a saab because it had stopped spinning and the exhaust wheel on it looks a similar colour to this gt-rs
Im wondering if it was running to lean, or if it was on e85 or another type of fuel, there is very limited info from the seller as he bought a rebuilt sr20 and it came on it.
I would personally buy one new if you can't see it in person, heck I'll even throw in the Hypergear turbo idea... probably matched performance and new for a little more than that 2nd hand turbo... not to mention awesome support & warranty
buying a 2nd hand turbo is always a bit sketchy as it is super easy to clean any oil out of the comp housing to mask seal issues.
Buying one 2nd hand without seeing it in person is even more sketchy.
I'd suggest the hypergear line. Message Tao and tell him what power range you're looking for and he will tell you which turbo will do it with the best response. Easy; and as Johnny said it will have a warranty.
I'd be willing to bet it's not that much more expensive either
I believe the guy that there is no shaft play and have had luck buying used turbos before that are still running fine 10 years later. Anyway what is the hypergear equivalent to a 2871r 52t .64 or gt-rs. I know they are the same lets not do the Hks vs garrett debate on this turbo.
I don't see the point of going one size up with a 2860rs .64 aka disco potato .64. I don't want to change the cams from stock and want 230-250rwkw. I'm thinking upto 20 psi boost no more on 98 octane.
Stock turbo is fun and handy around town but I'm just bored with it really
mate be VERY careful about buying any second hand
I just went through the headache of buying "5000km old" GT SS turbos, looked fkn immacualte, mechanic inspected said fractional shaft play on one, oither was g2g.. once installed it was fked out and wouldnt boost properly when getting tuned.
Cost me an extra $5k for new turbos, stud kit, labour of the changover, tune and then the extra 2 and half hours of tuning already conducted on the old set (what should have been 6k for my job turned into 11) because a second hand turbo that seemd fine was bad
Not saying this will happen to you, but you need to ask yourself is the 1k ish saving worth the thousands of dollars of risk and the uncertainty of what your getting. Plus the GT2871 (or equivelant) will be a more powerful unit, so it depends if you want more room to move.
my 2c
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
