They do, I just didn't want to be the bearer of bad news. His mech possibly ripped him off.
There is no way a 6mm line would restrict flow that much anyway, the reg only has a 2-3mm hole bypassing fuel. ;)
Pretty sure they are 8mm od not id, I did the upgrade myself to -6 lines which off the top of my head are 8mm id, have too double check, but that standard size would start to restrict flow at around the 350ish mark depending on setup
I'm on about the hard line not the hose, which would be 8mm id. The reg size restricting flow from the rail is different too the hard line restricting flow too the rail, but it sounds like its sorted so all good. ;)
-6 is 6/16th ala 3/8" ala 9.5mm id
I have seen 450kw on e85 through standard 8mm or 5/16 lines (or 6mm internal hardline). Don't know what he is on about, unless you have a carby and run 4psi fuel pressure?
Greg from a few posts up made 400kw through an auto, stock fuel lines, rail, Nismo reg. As we found, it was the shitty Ryco that held him back, probably the same reason most fuel systems fail the flow test.
Not sure where the stock lines become a restriction because everyone just assumes they need to upgrade the fuel system by then. Now the Walbro e85 pumps are available, going to externals/surge tank isn't really required on the road, so more people are pushing the boundaries, while keeping the factory rails and lines for stealth.
  • Like 1
Does this mean if u get ur Car tuned with a new fuel filter, it will soon lean the tune right out as it clogs? Or is there a decent brand of filter or bigger filter that won't clog... As easily anyway? Currently have 1300cc injectors in an just run in my new engine, I only have a Bosch 040 fuel pump which tuner said would max around 500hp with e85. N said maybe a twin in fuel tank mite be a possibility as I don't really want a surge tank taking up the already small boot. Or is there in tank single fuel pumps that'll run 600hpatw no worries. These "E85" pumps, are they fine for normal fuel too? As I'll be running wotever suites at the time.
Stainless steel mesh filter instead of Ryco/Nissan OEM or other paper style, as espoused by Scotty. look for his posts on the topic, of which there is probably one IN THIS THREAD.
E85 pumps are fine on petrol. Twin pumps is not as good as a single. If one of a parallel pair dies, you still get fuel flow, but not enough and you get a lean out and bang.
True. If you have the ability. There's a lot of ECUs out there that don't.
get with the times :)
saved my motor on the track last time, car cut out then gave it another hit on the straight and realised.. fuarkkk my AFRs are lean as..!
turned out my FPCM died so my dual relay setup with my own resistor pack was only giving my pump ~10V, then earthed the 2nd relay and away I went again till I snapped my front anti roll bar link LOL
You used an expensive ecu to protect your engine from your poorly designed wiring arrangement. If you had just run a standard direct power feed like I suggested you wouldn't be having this issue, and no expensive protection would be required. :P
I must admit, I am a little jealous, I would love the new Haltech Elite...
hahaha I really wanted a low voltage step down!
hey wasn't a poorly wiring arrangement, the only flaw in my setup was relying on the factory FPCM to give a signal to my relay to route the ground into the resistor pack and once a signal was given from the FPCM the relay would ground off the negative feed into the pump.
Positive side runs into another 40AMP relay which goes into a 30AMP fuse into the battery.
I had an issue last time I went to my tuner to raise my boost and get my tune touched up - said fuel (e85) was leaning out when we tried to bump up the boost and injectors (nismo 740s) were near max
Said it could have been a number of things eg. my 044 was on its way out or perhaps a simple blocked filter or fuel lines
ive been a bit slack and im yet to go back but I have changed my filter since and car does seem to be running a bit richer
what mesh filters are people running? and do you still change them every 5k or longer?
You are probably better off using a PWM load based output from the ecu Johnny, running through a 40 amp solid state relay. Ditch the FPCM all together, or still run it as a power feed cutoff through the feed relay.
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
