As stated in the title brand new dry sump kit for RB26DETT will fit R32, 33 or 34 GTR requires modified front sway bar for clearance of the pump (Whiteline sway bar supplied with R32 GTR kit) The kit has been extensively tested on several 450 + KW GTR's and is the kit the Employment Medicine R32GTR that will be running at world time attack is fitted with.
The kit consists of.
1 x Peterson (R4 Model) 5 stage oil pump.
1 x billet oil pump mounting bracket.
1 x Peterson 3 gallon oil tank.
1 x oil tank mount.
1 x Breather tank (for the main oil tank)
1 x billet drive spindle to suite either ATI 1000HP/ATI600HP balancer.
1 x billet oil block (replaces factory heat exchanger oil filter mount).
1 x remote oil filter mount.
1 x Custom internally baffled RB26 sump with 3 oil pick ups. (front diff not included).
All oil pump drive pullys and belt.
All bolts required.
All the billet parts in the kit are machined from 7075 T6 aircraft grade aluminium and anodised black.
The only thing required to fit the kit are braided hose and fittings.
Please Note; The pump shown in the pics attached is the older style G Rotor Peterson 5stage pump the kit is now supplied with the newer R4 style pump.
THE PRICE FOR THE KIT IS $7500.00 INTERESTED PARTIES PLEASE PM OR CALL ME ON MOB PH 0417305401. DAZ.
https://www.sau.com.au/forums/topic/449561-gtr-dry-sump-kit/
Not that I can afford it - for me this is the type of gear dreams are made of... but just so i understand it better, im assuming the tank would get mounted in the boot and the oil line gets mounted under the car or what?
Gavin
Yeah Gavin the pump in my set up is mounted in the boot with the lines running under the car as my car still has rego. A lot of guys with track only "Non Rego Cars" will often mount the tank on the passenger floor.
Hi,
Can you also provide a pump and pulleys for a RB30?
Hi racegtst the pump and pulleys will be the same but I would need to machine a separate bracket for the pump mount if you are definitely interested send me a pm and we can discuss further.
that isn't an r4 pump. nice kit.
Please read the entire post mate i do mention at the bottom of the post that the pump pictured is the older style G Rotor pump but the kit will be supplied with an R4 Pump.
  • Like 2
  • 3 weeks later...
And how much use has the pump had??
Everything in the kit is brand new mate this is a brand new complete kit.
As this is the last full kit I have for sale as I have two more going onto some project cars I'm willing to take $6500.00 absolute bottom dollar to move it.
  • 3 months later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
