Thats weird. I wonder what clay bar you are using?...
Ive gotten overspray off without fail with a simple meguiars clay bar.
mothers clay bar (yellow), I got lazy and hadn't touched it till few months later, I guess it bonded to the glass it more
oh. guess your gonna be solving the issue :)
just did a quick google, most people say a razor blade and alot of patience, or alot of people say nail polish remover
doesn't catch very well with blade due to curvature, will try nail polish remover tmrw
Use a razor blade, you cant really destroy the windscreen unless your stupid with it. Just angle it (like your using a scraper) and back and forth over the windscreen. I did it to remove overspray on the windscreen of the ute i drive out to work not to long ago. Only takes about 5-10 mins
didn't pluck the steel wool idea out of my ass :no:
Warm soapy water (dishwashing liquid)
Hand held razor scraper
0000 or 000 steel wool from bunnings
Single passes with razor
same with steel wool (light'ish not a hard rub or circular)
test in a corner if your dubious
