There never was a stock 300GT manual, so hard to say how well it will drive.
Given that.. I think that is a cheap price, make sure you get it in writing that this is a complete 'turn key' job and they will resolve any issues it creates. As it is unlikely anyone has done this before, so there is likely to be several 'unknowns' along the way.
My guess is that figure is for the mechanical work alone..
Thanks for the replies. Its my first auto car. My previous was a renaultsport clio which was very entertaining. Im finding the 300gt a little boring by comparison. After the responses and talking to a couple people I think I might just leave it as is until I can get something better. Lesson learned. Dont buy autos
Yeah you will need the interior trim too and some form of electronics to run it? Because the standard ecu is for an automatic.
FWIW in my R34 the auto ECU runs fine with the manual box, even the Nistune works fine. Your mileage may vary.
I know electrical will be annoying. What benefits is there of going manual. Is will still be a gutless 30dd
Cos manual = more fun?
Indeed manual does = more fun. Shame there is f all manual sedans around.
There are a few.. when I bought mine, there was 2 others on carsales. But at the moment, it seems the only 350GT sedan on there is a CVT.
Don't say that... Whilst a manual 350GT (for example) may be more 'fun'... I enjoy my 5 speed sports auto far more... torque torque torque and very responsive... + the manual mode is good fun if you want to hold gears :)
Have you considered selling your 300GT and using the money that you would have outlayed (eg: $3000+) towards a 350GT Coupe?
Edited by Sikahalv
I would just hang out until a 4dr manual appears for sale. Too many unknown 'gotchas' with converting a 300GT to a manual, unless you know someone who has done it before. You could possibly need a whole aftermarket ECU to make it work properly..
I decided to not go ahead with the conversion. As much as I would prefer a manual I may look into a v36 sedan with the better engine and hopefully better auto. If the 5 or 7 speed auto is greatly improved over the 300gt then I could forgo a manual I a suppose. Anyone gone from the old v35 auto to the newer? And are they that much more responsive?
I Drove a V36 sedan, 350 GT, 5 speed auto. I was keen to buy, but the dealer could not supply the de-reg papers from Japan. Despite having a 235kw engine I did notice any major performance increase over the V35 coupes. I think it may be on account of it being heavier, and apparently they have less torque.
It was a nice car, but there was a bit of lag from the paddleshifters when changing gears.
I settled on a V35 coupe (we have a 7 seater Dualis for my wife/kids anyway) and don't regret a thing. Without a doubt, the best car I have ever owned.
I thought the VQ35HR had the same torque figure? It recovered the torque the DE revup engine lost and increased power further.
And it was 230kw in the V36.
Edited by sonicii
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
