Car has got internally standard s13 SR20DET
stock turbo and manifold
Turbo back 3" exhaust
Locked diff
18x10,18x9 rota grids
BC racing coil overs
Brand new rubber all round
Bride replica seats
4pt harness's
S15 dash
Blue led cluster
Stripped interior
Sound deadening has been fully removed and inside painted green
I have for this car but not fitted is Z32 AFM, NIStune ecu, S15 inj, S15 turbo (needs rear housing as it is cracked) Then this car will be pumping out a mad drift setup 200rwkw. all you need for bulk amounts of fun!!
Car is located in Newcastle NSW you can call or message me on 0478 690 223
$5500 ono
Cheers David.post-27523-0-67561700-1413501494_thumb.jpgpost-27523-0-71337600-1413501499_thumb.jpgpost-27523-0-03844600-1413501506_thumb.jpgpost-27523-0-34213900-1413501513_thumb.jpgpost-27523-0-68640100-1413501519_thumb.jpgpost-27523-0-64493700-1413501525_thumb.jpgpost-27523-0-69494200-1413501535_thumb.jpgpost-27523-0-45112600-1413501545_thumb.jpg
Edited by yo_stock
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
