Hi Folks,
I have some R34 Standard bits and pieces that I do not need. I was going to post up more, but some of it (not listed) is still stuck on the car because the engine blew up and it's in a workshop.
So please buy some of it so I can afford to get it fixed thanks.
Note: I am unsure on some pricing. If you see it elsewhere listed for less, sold for less in the past etc, just PM me and I will adjust to suit.
THE PANELS ARE IN KV2 PAINT COLOR
Left and Right Front Guards $300
Bonnet+ Latches etc $180
Front Plastic Guards for infront of Wheels (pair) $90
Reo Bar 200 (just the actual bar, not the headlight supports, unless you want free S2 headlight supports)
Front Bar (series 2, headlight supports can be thrown in to fit it) 100
Headlights (pair) $300
Front Wipers $40
4x Stock Wheels (brand new tyres, literally 5km on them) $400
Window Switches FOR A SEDAN - All 4 doors. $60
Head Unit (Clarion, its blue.. it works... etc) $40
R34 Auto Transmission $150 - This is in retardedly un-farked condition. Believe me, I'm from the internet.
Radiator 80
Radiator Shroud 50
(please take them both)
STD Front Sway Bar 40
Front Indicators (series 1) 40
Sedan Rear Lights 150
R34 Stock Turbo Triple gauges + plug $100?
R34 Indicator Stalk $40
R34 AUTO clock spring $100
R34 Front Strut Brace $40?
VDO Digital Oil temperature gauge. 52mm. Works perfectly. $60
I'd really, really, really, really, really, really prefer pickup over sending them. Unless you want like, the entire front end in which case i'll lop the price off and send it.
https://www.sau.com.au/forums/topic/449794-vic-r34-stock-stuff/
  • 3 weeks later...
  • 2 months later...
  • 4 months later...
Right. Figured I'd bump this.
Still have the following!
Bonnet + Latches etc $200
Reo Bar $200 (just the actual bar, not the headlight supports, unless you want free S2 headlight supports)
Front Bar (series 2, headlight supports can be thrown in to fit it) $80
Front Wipers $40
Front Indicators (series 1) $40
Sedan Rear Lights $150
Radiator + Radiator Shroud $120, No leaks, works perfectly.
1 DIN Head Unit (Clarion, its blue.. it works... etc) $40
Climate Unit Computer thing and center surround - $80
Stock Front Sway Bar $30
VDO Digital Oil temperature gauge. 52mm. Works perfectly. $50
R34 AUTOMATIC clock spring $100
R34 AUTOMATIC dash cluster, 100,000ish kms. All works. $100?
Everything rather negotiable. As in, really very negotiable.
In Glen Waverley, VIC.
  • 3 weeks later...
Reo Bar $200 (just the actual bar in the center, not headlight supports - this is the bit people cut for FMIC's)
Front Wipers $40
This is what I still have.
(i.e no headlights, only tail lights now... and an excuse for a bump)
  • 1 month later...
  • 3 weeks later...
Totes sold a strut brace.
Also for you auto guys out there that have somehow killed your Torque converter (i.e - Noone ever) I have a rebuilt torque converter because ... reasons.
I'm 95% sure that I do - But these are headlight supports for series II - They are not the same for a series 1 front bar, and will not fit :P
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
