Hi guys,
Just after some opinions on how these cams would go. They have confirmed 444BB Will suit NEO with vct.
My setup is
RB30, Neo head with springs and ti retainers
Forged bottom end, etc etc
Gt35
Wanting to keep the VCT for a bit more response, car is Auto and will be street/Drag
Wanting to make around 500rwhp on 98 if possible
Edited by Huzqld
https://www.sau.com.au/forums/topic/449847-neo-cams/
especially because the RB30 is basically a longer stroked RB25, lift is more important to increase than duration.
So if this car is a daily driver it might be worth looking into some lower duration/higher lift option.
however that combination is more harsh on the rest of the valvetrain and is potentially trickier to fit.
If it's just a weekender then don't worry those cams will be awesome on boost.
If you desire response over top end power the factory cams are a great option. especially in the Neo as they have a bit more lift than the 33 cams anyway.
glad to hear you're keeping VCT though
https://www.sau.com.au/forums/topic/449847-neo-cams/#findComment-7411447
IMO the whole point of having plain buckets is to allow the use of more aggressive lift ramp on the cams . The idea being beater breathing through the valve opening further rather than longer . Longer period or duration cams IMO are better suited to engines turning higher revs all the time and may not play nice even in an RB30 around town .
I think cams need to be chosen with CR in mind and the inlet manifold/throttles style too . Single throttle inlets will make longer cammed engines grumpy because of the pressure fluctuations in the common plenum chamber , not as bad with ITBs because the throttle plates tend to block the reversions .
Your call but as mentioned less duration even at the same valve lift would be easier to live with .
A .
https://www.sau.com.au/forums/topic/449847-neo-cams/#findComment-7411556
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
