Hi guys,
Just after some opinions on how these cams would go. They have confirmed 444BB Will suit NEO with vct.
My setup is
RB30, Neo head with springs and ti retainers
Forged bottom end, etc etc
Gt35
Wanting to keep the VCT for a bit more response, car is Auto and will be street/Drag
Wanting to make around 500rwhp on 98 if possible
Edited by Huzqld
https://www.sau.com.au/forums/topic/449847-neo-cams/
especially because the RB30 is basically a longer stroked RB25, lift is more important to increase than duration.
So if this car is a daily driver it might be worth looking into some lower duration/higher lift option.
however that combination is more harsh on the rest of the valvetrain and is potentially trickier to fit.
If it's just a weekender then don't worry those cams will be awesome on boost.
If you desire response over top end power the factory cams are a great option. especially in the Neo as they have a bit more lift than the 33 cams anyway.
glad to hear you're keeping VCT though
https://www.sau.com.au/forums/topic/449847-neo-cams/#findComment-7411447
IMO the whole point of having plain buckets is to allow the use of more aggressive lift ramp on the cams . The idea being beater breathing through the valve opening further rather than longer . Longer period or duration cams IMO are better suited to engines turning higher revs all the time and may not play nice even in an RB30 around town .
I think cams need to be chosen with CR in mind and the inlet manifold/throttles style too . Single throttle inlets will make longer cammed engines grumpy because of the pressure fluctuations in the common plenum chamber , not as bad with ITBs because the throttle plates tend to block the reversions .
Your call but as mentioned less duration even at the same valve lift would be easier to live with .
A .
https://www.sau.com.au/forums/topic/449847-neo-cams/#findComment-7411556
