Bought these RCA from Japan for my R32 GTSt, Just fitted them and the circlip doesnt bottom out and locate the ball joint on the arm like it should
Its an R32 GTSt LCA 100%, I am wondering if they sent me a rear or a front R33 one or something that allows for a different height between the flange of the arm and the circlip groove?
Thoughts...people know the difference between all the relative front/rear and model ball joints?
https://www.sau.com.au/forums/topic/449880-nagisa-auto-rca/
  • 2 months later...
LOL, so now that I have had some machine shims machined to suit the OD of the ball joint I have managed to pack the difference in height so now happy.
But....sadly this brings me on to the next problem. The shank is different in taper and diameter.
http://www.rhdjapan.com/nagisa-auto-hyper-roll-center-adapter-front-nissan.html
They are claiming the same part number but appears as though they use different tapers so fark knows why they sell what appear to be suited to R32 owners S13 ball joints.
Can anyone confirm the differences between ball joints between various S-model platforms and R32s???
The taper on the Nagisa Auto RCA appear to be thicker at the top. Tempted to turn them down but fitting them in a lathe wont be exactly easy. This is starting to get frustrating :(
Seems in hindsight I shoudl have checked Ikeya who list different part numbers. Seems they are the only ones that care about being right rather than close enough is.... I dont want to spend the money but at least I can be sure they will fit. After buying new bushes, RCAs etc the std front arms already owe me about $350-400 and really want to try and make it work if I can find an RCA for an R32 GTSt
http://www.rhdjapan.com/ikeya-formula-roll-center-adjuster-pillow-lower-arm-kit-nissan.html
https://www.sau.com.au/forums/topic/449880-nagisa-auto-rca/#findComment-7452392
Just found this posted on a forum by Cazman
S13 Front
Taper low diameter 15.8mm
Taper High diameter 18mm
Taper length 19.5mm 20mm
Diameter where it presses in 41mm
S13 Rear
Taper low diameter 15mm
Taper High diameter 18.6mm
Taper length 23mm or 23.5
Diameter where it presses in 38mm
R32 front
Taper length 23mm
https://www.sau.com.au/forums/topic/449880-nagisa-auto-rca/#findComment-7452488
OK some other numbers copies and pasted from other forums
The S13 balljoint has the following measurements:
length of taper 19.5mm
diameter at top of taper 16mm
diameter at bottom of taper 18mm
length of threaded section 22mm
The R33 balljoint has the following measurements:
length of taper 24mm
diameter at top of taper 15mm
diameter at bottom of taper 18.5mm
length of threaded section 23mm
It seems the Nagisa listing is wrong and need to buy their S14. Silly bastards. LOL anyone need S13 RCAs ?
https://www.sau.com.au/forums/topic/449880-nagisa-auto-rca/#findComment-7455428
So broke out the verniers and hunted through boxes of rubbish to find my old R32 GTSt ball joints.
The R32 balljoint has the following measurements:
LOL, so same as R33, provided those dimensions posted above for R33 are correct. But based on Sick_R31 is saying they are and finally can go spend another small fortune with some peace of mind
https://www.sau.com.au/forums/topic/449880-nagisa-auto-rca/#findComment-7458069
From my reading most S14/15 and later R33/34 platofrms use the same front to rear. The R32 uses different ball joints from to rear.
I will measure them up though as I have the R32 GTSt rear and the new R33 GTR rear cradle with Nismo arms etc so have them there to measure up.
https://www.sau.com.au/forums/topic/449880-nagisa-auto-rca/#findComment-7459307
Hey Roy, if you come across the rear, outer LCA ball joint sizes can you post them up too? Or are all the ones you've been posting for the rear LCA outer ball joint?
Are you chasing replacements or looking to get something machined up? For replacements http://www.eziautoparts.com.au/steering-and-suspension/lower-ball-joint-bj261.html and measurements i should be able to get some by Friday
https://www.sau.com.au/forums/topic/449880-nagisa-auto-rca/#findComment-7461205
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
