Bought these RCA from Japan for my R32 GTSt, Just fitted them and the circlip doesnt bottom out and locate the ball joint on the arm like it should
Its an R32 GTSt LCA 100%, I am wondering if they sent me a rear or a front R33 one or something that allows for a different height between the flange of the arm and the circlip groove?
Thoughts...people know the difference between all the relative front/rear and model ball joints?
https://www.sau.com.au/forums/topic/449880-nagisa-auto-rca/
  • 2 months later...
LOL, so now that I have had some machine shims machined to suit the OD of the ball joint I have managed to pack the difference in height so now happy.
But....sadly this brings me on to the next problem. The shank is different in taper and diameter.
http://www.rhdjapan.com/nagisa-auto-hyper-roll-center-adapter-front-nissan.html
They are claiming the same part number but appears as though they use different tapers so fark knows why they sell what appear to be suited to R32 owners S13 ball joints.
Can anyone confirm the differences between ball joints between various S-model platforms and R32s???
The taper on the Nagisa Auto RCA appear to be thicker at the top. Tempted to turn them down but fitting them in a lathe wont be exactly easy. This is starting to get frustrating :(
Seems in hindsight I shoudl have checked Ikeya who list different part numbers. Seems they are the only ones that care about being right rather than close enough is.... I dont want to spend the money but at least I can be sure they will fit. After buying new bushes, RCAs etc the std front arms already owe me about $350-400 and really want to try and make it work if I can find an RCA for an R32 GTSt
http://www.rhdjapan.com/ikeya-formula-roll-center-adjuster-pillow-lower-arm-kit-nissan.html
https://www.sau.com.au/forums/topic/449880-nagisa-auto-rca/#findComment-7452392
Just found this posted on a forum by Cazman
S13 Front
Taper low diameter 15.8mm
Taper High diameter 18mm
Taper length 19.5mm 20mm
Diameter where it presses in 41mm
S13 Rear
Taper low diameter 15mm
Taper High diameter 18.6mm
Taper length 23mm or 23.5
Diameter where it presses in 38mm
R32 front
Taper length 23mm
https://www.sau.com.au/forums/topic/449880-nagisa-auto-rca/#findComment-7452488
OK some other numbers copies and pasted from other forums
The S13 balljoint has the following measurements:
length of taper 19.5mm
diameter at top of taper 16mm
diameter at bottom of taper 18mm
length of threaded section 22mm
The R33 balljoint has the following measurements:
length of taper 24mm
diameter at top of taper 15mm
diameter at bottom of taper 18.5mm
length of threaded section 23mm
It seems the Nagisa listing is wrong and need to buy their S14. Silly bastards. LOL anyone need S13 RCAs ?
https://www.sau.com.au/forums/topic/449880-nagisa-auto-rca/#findComment-7455428
So broke out the verniers and hunted through boxes of rubbish to find my old R32 GTSt ball joints.
The R32 balljoint has the following measurements:
LOL, so same as R33, provided those dimensions posted above for R33 are correct. But based on Sick_R31 is saying they are and finally can go spend another small fortune with some peace of mind
https://www.sau.com.au/forums/topic/449880-nagisa-auto-rca/#findComment-7458069
From my reading most S14/15 and later R33/34 platofrms use the same front to rear. The R32 uses different ball joints from to rear.
I will measure them up though as I have the R32 GTSt rear and the new R33 GTR rear cradle with Nismo arms etc so have them there to measure up.
https://www.sau.com.au/forums/topic/449880-nagisa-auto-rca/#findComment-7459307
Hey Roy, if you come across the rear, outer LCA ball joint sizes can you post them up too? Or are all the ones you've been posting for the rear LCA outer ball joint?
Are you chasing replacements or looking to get something machined up? For replacements http://www.eziautoparts.com.au/steering-and-suspension/lower-ball-joint-bj261.html and measurements i should be able to get some by Friday
https://www.sau.com.au/forums/topic/449880-nagisa-auto-rca/#findComment-7461205
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
