Hi all,
We've recently bought a m35 stagea which came with tein coilovers.
Given that this is the family wagon, these coilovers are tricky to adjust for a nice ride, and may be due for a rebuild.
I would prefer to replace it with the stock axis or rs4 suspension, or preferably the nismo aftermarket shocks and springs.
Does anyone have any of the above for sale? Willing to pay for courier for the right parts.
Thanks
https://www.sau.com.au/forums/topic/450101-m35-stagea-suspension-change/
Hi all,
Thanks
Where are you located? I might be interested in a trade
Im in melbourne. Se suburbs specifically. What you got brick?
I am based in sydney so probably would be more Hassle then needs be.
My car has the factory upgrade suspension which sits 2" lower then stock but gives a really nice ride being the nissan upgrade set
Thanks all,
On this subject, which is the better option out of the nismo s tune and bc br coilovers?
Looking for a nice sporty ride with handling to suit. Not too firm, but not too mental either. This is the family wagon after all
Bc's. $1149 delivered in 2-5days.
S-tunes are the same price but you'll be waiting 2-3 weeks. I Don't know if they've changed them in the last couple of years, but the s-tunes in my r34 weren't height adjustable and didn't have the adjustable front tops.
  • 1 year later...
Hi folks, I realize this is an old thread, but I have just bought an 04 ARX and it has leaking shocks. What options do I have in coil over or even performance air ride.. I'm wanting to maintain the ride height where I can, but stiffen up the lateral movement with sway bars and braces.. I'm hoping I'm not too late to the party and look forward to learning more and with any luck comparing notes :) cheers
Ive got a spare set of AR-X Bilstein shocks with King Springs. PM me if your interested
BC Coilovers, Tein Coilovers, HKS Coilovers, MCA Coilovers, Nismo S-tunes. .....
Spoke to JustJap re the BC's and they told me with the ARX, the wheels will sit just off the guards at their most extended point.
On the others, I can't seem to find anything on whether they are ARX compatible. I really don't want it lowered much at all, if any... difficult aren't I :-/
Sway bars from SuperPro make a HUGE difference
Agreed, fully intend on replacing the bars once I get the car and figure out all the bushes that I need to replace in the one job... hope I can stretch the purse strings lol
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
