For Sale R34 GTR
454kw (610hp) at 24psi (E85) and 360kw on 98ron with 20psi (safe tune)..... flex fuel set up
I have decided its time to part with my car after nearly 4 years of ownership. When I bought it, it was near stock.
Previous owner was an older gentleman who owned with for 5 years and did 10000kms in that time.
The reason I originally bought this car is because the whole car was absolutely immaculate (still is), No rust, no accidents, no jacked on rails... These cars are getting extremely hard to find. If you think you can buy a 40k GTR then go ahead, but enjoy the rust, accident history or engine thats gone.
I have pretty much rebuilt the whole car. Including new forged motor, Brakes, Tyres, battery, full fluid change, new belts, new MFD.... I could go on.
My aim with this whole car was that I wanted a neat looking GTR and I wanted it to be a street based GTR. So every part of the build has this in mind. The car is smooth and drives like a stock car, is responsive.... yet packs a super mean punch.
Engine:
Rebuilt 1500kms ago
CP Pistons
Manley Rods with ARP Rod Bolts
ARP Head Studs
ACL Race Bearings
1.2mm oil restrictors
Reimax Oil Pump Gears with high pressure oil pump
Tomei Oil Baffle
Tomei 264 degree Cams
Tomei Cam Gears
Nismo Twin Plate Clutch
1.3mm Metal Head Gasket
Metal intake and exhaust gaskets
Nismo Timing Belt
All new belts
Intake, Exhaust and Fuel:
HKS 25/30 turbos
HKS Wastegate Solenoids
HKS 1000cc Injectors
Walbro 460L pump with relay for direct voltage
Nismo Fuel Pressure Reg
Nismo Radiator
Nismo Radiator Cap
Nismo Oil Cap
Sard Air/Water Separator
Greddy Oil Cooler with Relocator
Spitfire Coilpacks
HKS Sparkplugs
100mm Intercooler with metal intercooler piping
Blitz BOVs
Apexi Pod Filters
KTS Intake pipes (fits to standard airbox if required)
Twin 2.75” into 3.5” Front Pipe
3.5” Metal Cat
3.5” Apexi N1 GT Cat Back
ECU Controls:
Haltech Platinum Pro
Haltech Flex Sensor
Haltech Dual Widebands
Blitz Boost controller
Nismo 320km Dash (33000kms on Dash installed at 40967kms)
JVC Headunit with blue tooth phone integration
Chasis:
Tein Suspension with EDFC Remote Damper Control
Tein EDFC Controller
Near new 2 piece front rotors
New rear slotted rotors
Hawk Pads all round
Exterior:
Nismo Z Tune Bonnet
Nismo Z Tune Front Bar
Nismo Z tune Side Skirts
Nismo Z Tune Rear Pods
Nismo Black Indicators
Tein Bonnet Dampers (no bonnet stick required)
Eyelids
Carbon Fibre Ganador Mirrors
Carbon Fibre Rear Bar Plate
Carbon Fibre Wing Stand
Carbon Fibre Wing Blade
Rays TE37s (18x9.5 +12) With custom grey flake powder coat
Rays Valve Caps
Nismo Wheel Nuts
New Street Semi Slicks (265/35/18)
Servicing/Oils:
New Front and Rear Diff Oils (Synthetic 75w90)
Full Attessa Oil Flush
New Gear Box Oil (Transmax Z)
Engine oil 500km old (Castrol 10w60)
There is probably stuff that I have missed. Just pics and work that have gone into this car should speak for themselves.
Brisbane
$65000
1654273_10151945129213379_1870911800_n_z
150163_10151230370206329_232891348_n_zps
10403652_10152462257058379_8857278366394
1015760_4281320049815_604751371_o_zpse2a
967148_646331122047106_1376766019_o_zpsc
https://www.sau.com.au/forums/topic/450362-sleeper-454kw-r34-gtr/
