So I'm half way through installing a FMIC kit yesterday and decide that its a great time to check on my turbo while I have all the piping off. I take much of the piping off and find oil in some of the pipes. It isn't all the way through though thankfully. It seems to go from the turbo to only the first arm of piping, so not even to the section that dives down to the IC through the engine bay floor yet (so oil for about 40cm from turbo).
I checked the turbo itself and there was a little oil on the inlet. I checked the wheel for movement and there is no real side to side movement, but a little back and forth, maybe 1mm.
It feels to me like the condition of the turbo wheel/bearings etc is ok, but the oil leak suggests the rear seal is worn. Am I on the money here?
The car runs factory boost (for now), has done 125,000kms, and it runs fine.
So, what do we think the problem is, and importantly how long would you expect it to last? Also if I leave it as is what will be the consequences? Will it just get more and more smokey as the seals wear out more, or worse?
thanks
Oil could have got in there from the engine breather return to inlet.
1mm of movement is heaps. But I doubt it's 1mm. People can't judge less then with their fingers typically!
Just drive it. Pretend you never saw the oil.
But plan on getting a better turbo because the stock one sucks!
they all have a bit of oil in them, its most likely caused by positive crank case pressure which results in the oil air breather to spit oil into the intake of the turbo, then it throws it out the hot side, and because it only throws out such small amounts its not going to travel all the way to the IC.
when i pulled my old 180 apart the oil was all through the IC and everywhere.
I'd say its fine for a while, if you have plans on doing a new turbo + injectors + ecu etc then don't worry about it, save up and buy those things, don't waste money on factory turbo seals lol.
EDIT - What ben said ( beat me too it haha)
Edited by vetter2769
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
