  • Replies 52
Do you know if the head still will fit a RB25DET VVT model inlet manifold. I think there were two designs in the non vvt heads one will and one wont fit an inlet manifold. Am thinking of doing a head with GTR cams and solid lifters so dont need the VVT. However I need it to fit the manifolds from DET motors.
Thanks
Hey mate
Yes the DE head does fit a DET head but uses some differnt lines and stuff. Have a look in the RB30 R33 build up in the Forced Induction section for more info.
Take it easy.
Adm
  • 3 weeks later...
  • 2 months later...
  • 3 weeks later...
riceline: can you pm me your mobile number (i think i have it already, but not 100% sure - got it off someone else who bought an inlet manifold off you a while back)
i'm interested in the plenum, the 25DE exhaust manifold, and whatever else you have lying around. need stuff for the top half of my 25/30DETC build. you haven't, perchance, had the plenum flow tested or anything have you? and who built it?
  • 4 weeks later...
Hey mate,
Do you still have the NISMO F.P.R.?
Thanks champ
Hey guys
I have a Heap of parts from my RB30 build up left over that I'm keen to get rid of. Sick of the space that they are taking up in the garrage. If you have offers please send them my way.
Once most of the parts are gone I will be Donating $100 to SAU as a thanks for all that SAU Provides for us.
Donated $10 So far
RB30 Piston rings (5 Only All complete though) $30 (cost me $90)
RB30E exhaust manifold - $Make an Offer
R32 RB25DE TOP FEED injectors $50
R32 RB25DE Non VVT head (No Valves or Lifters) Timing belt Cover, CAS Bracket, Cam gears and rocker covers $200
RB25DE bottom end (has Sump, Oil pump, Engine mounts - No Oil pressure sensor, Harmonic Balancer, Dip stick holder or Dip stick) $150
RB25DET Bottom end (Block, Pistons, Rods, Crank and Cradle) Replaced due to RB30 Upgrade - $200 - Sale pending
RB30E Head - $50
RB30 Inlet manifold Complete Inlet, Plenum, Throttle body and fuel rail - $20
RB30 Engine Mounts - $20
R33 GTS-T Custom Plenum $320 (I have not used it. It is still in box from when I first recived it in the mail. Purchased from the fourms. Has Plenum, Throttle body, TPS, Inlet manifold gasket and all bolts. Bolts onto std R33 inlet runners) - Sale Pending
R33 GTS-T 3Inch Turbo to Cat Dump Pipe wrapped in Heat Wrap $200 (Has not been put onto my car as it would not clear the undercarrage because of my RB30DET set up. Fits perfectly to a RB25DET)
Nismo Fuel Pressure Regulator - Universal/z32 style - $100
Thanks guys
  • 1 month later...
Hey guys few responces
BigCarl : No sorry mate - not as of yet still have to get my new ones. will put them up when i have my new ones in though
Bobjones: Sorry mate Sold
Daler32: don't think it will mate. But i will see what I can find out
Luke33gtst: don't have one sorry mate
Thanks guys
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
