I have a 1993 Nissan Skyline GTR R32 up for sale or swap. I'm over the car, it's my second one and I want to buy a series 5 fc Rx7 as I've always wanted one. Or something newer and more comfortable. Car was also originally bought from another member here about 4-5 months back now?
-Built 2.7L motor, sleeved to accommodate 88mm CP pistons
-HKS Step 2 rods and bearings
-ARP headstuds
-HKS Camgears
-GREDDY staggered 262/272 camshafts
-N1 oil pump
-R34 gtr crankshaft
-Custom 8L baffled sump
-PAR straight cut gearbox 1st-3rd
-GATES Timing belt and accessory belts all round
-Brand new century battery 1 week old
-Custom oil catch can
-750cc injectors
-New spark plugs bcpr6es-11 gapped to 0.8mm
-twin entry fuel rail
-Sard fuel pressure regulator
-Oil cooler
-Hks mushroom pods
-Z32 afm
-Oil filter relocation kit
-3inch turbo back exhaust
-Aftermarket aluminium radiator
-Aftermarker front mount intercooler
-Bosch 044 external fuel pump and surge tank
-Nismo shift knob
-Autometer boost, oil temp and oil pressure gauges
-greddy profec spec 2 boost controller
-Apexi power fc ecu with hand controller
-Tein adjustable coilovers
-Rear diff bushings have been changed
-Hicas disabled electronically
-Rebuilt r33 n1 turbos
The car used to make 340awkw but atm is running 252.8awkw on Incar's dyno on 14psi, it's got potential for alot more but turbo seals are on its way out so it's on a conservative tune. Plan was to throw on a gtx3582r and push over 400awkw but over it and want to trial out something I've always wanted before I buy an r34 gtr. I have also a spare power fc d-Jetro with map sensors and loom that was bought for the single conversion but not used. Also forgot to mention it's got a brand new bm57 Bmc in it as I was going to throw on evo brembos in preparation for the power it was going to make. The body's fair for its age and the interior is pretty immac if you consider its only got a tiny bubble compared to my previous gtr.
If the new owner wants to go down the same route and get the brembos, i can get them off my mate for you for $700 front and rear, and $1100 for d-jetro with brand new hand controller never used with map sensors and wiring harness.
It's got almost full year rego, 10 months from today pretty much and looking for a swap for a clean series 5 fc Rx7 with cash my way and I know what they are worth or $22000 Ono for my gtr and for what it's got its a very fair asking price and I'm also nego. Oh forgot to add, there's an entire folder with dyno sheets and receipts for all the work done to the car.
Car can be arranged to be viewed at Anytime during the week as I also currently left my job last Saturday. Located in Fairfield, contact number 0422 one two six 939. Strictly no tyre kickers or joy riders, test drives only when deposits taken otherwise ill take you for a spin thats IF you seem like a genuine buyer. Im still on the rocks in regards to selling it since theres not many series 5 rx7 on the current market i like so dont bother trying to low ball me im not in a rush. Ill consider fair negotiations with genuine buyers.
post-75344-0-14156400-1416715867_thumb.jpgpost-75344-0-52713800-1416715873_thumb.jpgpost-75344-0-03451000-1416715881_thumb.jpgpost-75344-0-64591500-1416715887_thumb.jpgpost-75344-0-70991300-1416715894_thumb.jpgpost-75344-0-05140100-1416715903_thumb.jpgpost-75344-0-52167300-1416715913_thumb.jpgpost-75344-0-29127500-1416715919_thumb.jpg
Edited by _Dee
https://www.sau.com.au/forums/topic/451003-wttwts-93-built-27l-r32-gtr-syd/
  • 3 weeks later...
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
