Hi all,
I've got a few new (electronic) gauges coming in the next few weeks and would like some info/help on installing them. I have a r34 GTT.
I've tried searching on the forum, but a little confused, so if someone can clarify please?
1. Oil pressure gauge - I've read i need to put a sandwich plate between the block and the oil filter. What do i need to connect from the sandwich plate to the gauge? Where can i get a decently priced sandwich plate for this job, and do I need to block off all but 1 port?
2. Water temp gauge - So i've read i need to stick a sensor in the radiator tube or on the radiator or something? How do i go about doing this? I don't see drilling into the radiator or hose is the right thing to do... is it?
cheers!
The oil pressure gauge, im assuming they run the stock sensor off the oil cooler (stock) plate like the r33. If so there is a plug in the intake side just behind the cooler/filter plate that you can use.
The water temp sensor, AFAIK people usually just buy the little adapter that goes in the middle of the top radiator hose. I dont like them but it will work fine. Search on the Just Jap website for water temp sensor adapter or something. They should sell them just to give you an idea of what your looking for
Not really sure what the stock oil cooler looks like. Do you have a pic of it? Also, would this mean i won't need a sandwich plate?
For the water temp sensor, is this the little adaptor you're talking about? http://justjap.com/autogauge-water-temp-sender-adapter-30mm.html
How does it work? Kind of like a t-piece with radiator hose on either side, and the temp sensor fitting in the small hole in the middle of the adaptor?
cheers mate.
As already discuss. You just need the little extender for the side of the block then your gauge sensor will screw in. Easy.
I ran a fitting and braidedline to a couple of fittings in order to run 2 sensors but OP doesnt need that
Is the stock plug easy to find behind the stock cooler/filter? Also, do i need to drain engine oil before i install any extender onto it for the sensor?
Haven't had a look to see where this plug is yet so not really sure what to look for.
Edited by suwidji
kk thanks!
will be changing my oil this weekend and hopefully chuck it on.
where can i get this extender for the oil plug behind the filter? so im not cluelessly walking into bunnings or wherever.
ALSO, does anyone know the diameter i need for the water temp adaptor? Not sure what the radiator hose size is, and only way to find out is if i take it off...which i would rather not do cos i wont have a car to drive to the shops to buy one with lol.
ok cool, i've heard it's NPT but i'll get both just in case. Standard part to get at bunnings?
im changing my oil anyway today, so i'll do it then. Is there a cap i need to take off the valve before putting the extender on? will oil start gushing out? lol
So i went under to have a look at where this plug is.. but not sure what I'm looking for.
Here's a photo of the filter, oil cooler behind it, and a small attachment om it which has some sort of plug covered in a rubber boot thing.
Where do I put my sender? Or am I looking wrong...?
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
