Engine out before lunch on Saturday.
Getting the manifolds off took longer than the engine pull (turbos get in the way of everything).
Engine pulled to chase down what sounded like an exhaist mani gasket leak. I was concerned when the gaskets looked fine :s But while I was prepping the manifold faces for re-install I happened to hold it at just the right angle and noticed daylight through the manifold wall :(
At least I found the cause. Hopefully a quick weld and it'll be good to go. Also installed a new knock sensor and harness because it is impossible to install in OEM location with engine in.
While the engine is out I will run new turbo coolant lines, chuck in the new clutch and fix up the air-con hardlines.
dang, good old chinese casting.
Not worth a change while everything's out? Maybe those new Ash manifolds? Not purchased direct obviously but a couple of the traders seem to be getting stock now. Dane (Houston) has advertised a couple sets not too long ago.
http://www.twinturbo.net/net/viewmsg.aspx?forum=classified&msg_id=177015&forum=classified&dtSearch=22
  • 1 month later...
So I ended up getting new MSP manifolds from the USofA. They are in customs atm.
Also have some top feed rails on the way which is a stuffaround to install but will be worth it in the end along with totally new fuel supply system.
The new manifolds have eaten my ECU allocation now tho, so we will see how nistune with the upgrade works out.
  • 1 month later...
Have had some progress. Got new manis on and engine back in.
Heaps nicer than the chinese stuff
received_10208442013197561_zpsxuctuffm.j
Got most of my fuel system stuff in 1 shipment
Went with Fuelab 42401 pump and 52901 regulator, cheaped out on lines etc with raceworks 200 series. Injectors I started with bosch 2200cc but as pointed out by some, they aren't e85 safe. Hopefully end up with Delphi 1400cc.
Had to get a new custom surge tank made to replace the custom tank I already had to fit in the limited undercar space. Thanks to Steveo's customs for that, and thanks to Al for the fitting welding and sealing work! And thanks Lisa for driving up after he forgot the filler :D
New tank is actually larger in volume than the old one, 3L instead of 2.7 but whatever.
Had to modify a few bosses etc on the plenum to allow clearance of the rails. I got a bit carried away and cut off and smoothed all the other redundant bosses. I returned to the original plenum off the car which had been polished (once upon a time) and port matched to the lower plenum (and the lower to the heads). Doing this meant I had to enlarge the throttle body openings to match the larger throttles. Seemed easier to do this than to do the upper to lower holes on the HPC coated plenum that already had larger throttle body holes (did that on my last zed, not fun).
While the plenum was off I took the oppertunity to re-do the cam covers is some kind of sparkly silver. It is kinda textured but shiny and I think will contrast the black wrinkle that the plenum will be finished in. I didn't pick the color, I sent Cara out for some 'grey or silver or something' and she did pretty well.
Before clear coat
received_10208409165096379_zps7haca5tw.j
Done
Starting to make up routes and lengths
Edited by MagicMikeZ32
I also have had the dash out to re-install some of the air con stuff that didn't get put back in after the wiring harness install (was pressed for time with an event the following day). With the dash out, I took the time to tidy up a stack of wiring.
I tried to enlist some help with the dash re-install but he wanted none of it.
And that's about where I am at. Dash is back in but still need to do the pods and the trims (and seats). Engine is in but haven't finished plumbing. Need to add a new bulkhead fitting because the fancy regulator has to be on a return line direct to the main tank.
System goes something like this:
Walbro 460 in tank -> surge tank -> fuelab external pump -> rails -> regulator -> main tank.
The surge tank overflow returns to the main tank via a cooler.
Still haven't decided the final routing of the 10AN feed line and a few other engine bay routings, but it is getting there.
So I made some more progress.
Installed new fitting in the bulkhead for the main return line from the rail, finished mounting the new in-tank pump and connected all the lines and re-installed bulkhead to the main tank.
Finalised the surge tank mounting and installed the Boom mat on it. It is a thermal and acoustic insulation, dimpled foil stuff with fibre stuff and a sticky backing. Also wrapped another section of exhaust that is closest to the tank and pump (I re-wrapped the dumps while the engine was out, and the front pipes are still wrapped).
Tank is 170mm x 180mm x 100mm.
I spent yesterday making a bracket to support the big ass pump. I actually made 3 brackets and modified one of them a few times, because I kept on finding better ways to do it.
I am still deciding on how and where to split the 10an into 2 x 6an and spent some time yesterday trying different runs. I am leaning towards splitting it about 30cm back from the drivers dump and running the 6an lines from there in a cool tube up past the dump and direct to the back of the rails. My reasoning is I have to fit a big 10an filter in before it splits and doing this in the engine bay makes things very cluttered with the filter and the 'Y'. The filter fits on the inside of the rail and the rail is still the lowest point.
I couldn't decide 100% so I put that on hold and started installing turbo/ic pipework, so I can get my loom in the right spot, so I can confirm that the braided lines to and from the rail are actually going to be in the right spot/right lengths (and not clash with wiring runs!).
Had a bit more progress. Finished the plumbing. Ran the regulator output for pump speed control. Made some guards and heat shields. Got dash back in mostly.
I ended up putting the ethanol sensor here. I am not sure how long the cable from the board in the ecu (nistune) is so I wanted to keep it fairly close. I'll run it through a hole in the floor if I have to.
This is where I have the 10AN filter and the split from 10AN to 2 x 6.
This is the drivers side dump, where the 2 x 6 lines run up the firewall to feed the rails. The lines are in a cool tube, but since I was making stuff I made a shield also. There is a stud on the firewall up a bit higher than dump height that the lines are secured with a p-clamp, and the shield is also secured to the same stud. The shield (somewhat) follows the contour of the firewall down to the floorpan and bolts to the guard that houses the filter and y splitter above.
This is the shield for the surgetank. Barely enough room but it is mostly not touching the zorst.
Did some more work on the plenum also as there was a few blanked off ports like the OEM PCV ports and stuff like that.
And painted it once I was happy with the smoothing out.
  • Like 2
nice work Mike.
Why the Ethanol sensor under the car? Could you not find any space in the boot? I'd be concerned if you scraped the car from sleepers
Same goes for the surge tank,
Looks like much hard work has gone into it.
Zeds don't have a boot, so technically are in cabin. Any fuel components in a zed boot need to be sealed off. Plus that's where the roof goes!
I am happy where the under car stuff is located that they are protected by the rails somewhat. I am more worried about the bottom of the fuel pump than anything else, but should be ok because I have a reasonable ride height.
The front pipes on the exhaust typically take the scraping over speed bumps etc, don't have too many issues in the rear.
  • 3 weeks later...
Nearly there...
Used up some more boommat on the shields. Everything underneath is now complete. Stupidly I had to re-do some fittings because I didn't get o-ring fittings for the pump and filter originally. Exhaust, starter etc all done. Took the oppertunity to clean the oil filters pre-turbos, not that they needed it.
Had a shit of a time installing the injectors. I ordered Delphi 1400s which are meant to be a 14mm top and bottom, but for whatever reason they came configured with a 14mm top and a 15.5mm bottom o-rings (wtf) with 2 stupid plastic rings either side of the bottom o-ring to keep it located.
For those interested, the injector bucket adapter is 13.70mm ID. After to and fro with the supplier, he sent me some other orings and told me to remove one of the plastic rings and file down the other (from 14mm down to something less than 13.70mm) and install 2 of the new orings.
This didn't work either, but luckily I ordered some new orings which I ended up using. They are a 14.22mm OD. Hopefully they don't leak.
This is not the config I ended up going with but the brown viton o-ring does do the sealing and the stupid plastic ring does stop it from moving up. I didn't take any pics of the config I ended up going with.
This is one fitted to the bucket
After I got the injectors and rail in, I collected my upgraded nistuned ECU from Karl @ Epic Automotive on Sat, and dropped off my balance tube for him to modify for the top feeds.
Shame I didn't tweak that the wiring for the injectors and coilpacks etc don't fit under the rail after the rail is bolted down, but I'm not going back there now I will live with the ugly (as long as nothing leaks!).
I also ran the connection for the ethanol sensor to the ecu and finished putting the cabin back together (drivers seat and steering wheel aside).
I am at the point now that I think I can prime the fuel system and see what happens redface.gif
  • Like 1
  • 1 month later...
For the interest of keeping current
ENGINE
Block bored 20 thou oversize, decked and o ringed, fitted with forged ACL race pistons and rings
Scat H beam conrods, fitted with ACL race bearings
Crankshaft linished and deflashed oilways
Modified oil pump for greater flow
Heads have received a lot of work with machining, porting and polishing, cc’d, flow tested
1mm oversize Ferrea valves
Competition valve springs
Compression set at 8.5-1.
Inlet manifold has been match ported to the heads and the upper plenum
Modified crankcase ventilation with catch can
(Jim Wolf Technology) JWT 400+ wild Cams
BDE (Brett Dempsy Engineering) modified Intake Cam gears
Tomei adjustable exhaust cam gears
A new set of hydraulic lifters fitted with shims has the motor running nice and quiet
2 x GTX 28/63 ball bearing turbos
Complete 2.5in intake to turbo to intercooler to throttle body piping upgrade
Massive 2.5 inch, ducted side mount intercoolers
54mm throttle bodies with match ported plenum
Selin twin AFM translator
Twin Apexi power air filters
Turbosmart, BOV’s
Ross Racing harmonic balancer
56mm Alloy Radiator
72 plate external oil cooler
Boost control by Blitz dual SBC controller
Engine management is by Nistune (upgraded firmware for flex fuel/launch etc)
Wiring Specialties wiring harness
AEM patch harness
EXHAUST
Custom 5 bolt, divorced dump pipes
Mike Smith Performance exhaust manifolds
Twin 3” system through hi flow cats, and pair of Varex adjustable Mufflers
FUEL/IGNITION SYSTEM
BDE (Brett Dempsy Engineering) top feed fuel rails with various modified stock bits to suit (balance tube etc etc)
Bosch 1000cc top feed injectors (these only installed so the car is drivable while injector issue is resolved.)
Walbro 460 in tank
Custom surge tank
Fuelab 42401 external pump
Fuelab 52901 regulator
Custom fuel cooler
Teflon braided lines front to back with various heat shielding
Multiple fuel filters, pre external pump, pre fuel rails, post fuel cooler (pre main tank)
Flex sensor
Battery has been moved to the boot area sealed in a battery box fitted with an isolation switch
Series two power transistor unit
HKS DLI Ignition Amplifier
Spitfire coilpacks
Engine earthing kit
DRIVELINE
OS Giken twin plate/lightweight fly combo
Chrome molly one piece tailshaft.
Richmond leader diff gears of 4.11 ratio
SUSPENSION
Bilstein PSS9’s coilovers
Powertrix front upper control arms
Powertrix front lower tension rods
Tune Agent rear camber
Tune Agent traction arms
Energy suspension bushings all round
Nagisa Auto Gacchiri Support fender braces
UAS HICAS lock out
BRAKES
Front - Stop Tech ST-40 calipers big brake kit
332 mm slotted, curved vein rotors
Braided stainless brake lines
Ferodo 2500 pads
Rear - Reliance Edge 297mm slotted rotors
Ferodo pads
Stone shields have been removed and tubular ducting has been fitted for extra cooling
WHEELS and TYRES
18x9 and 18x10 Gram Lights 57F-Pro
Also available is a pair of stock 16” wheels fitted with Mickey Thompson ET street radials for those nights at the drag strip
EXTERIOR
2000 model urethane front bar with Powertrix carbon air guides
Various undertrays
2000 rear tail lights
Modified stock bonnet
Modified nose panel
Genuine Trust/Greddy side skirts
UAS rear wing
UAS enclosed rear bar fitted with Perspex diffusers.
Ab-flug Aero mirrors
Custom made Miracle Zed Motors vented air guides for improved cooling to the radiator.
HID headlights
INTERIOR
Recaro SR3 driver and passenger seats on Z32 recaro rails
Stock gauges have been replaced with el panels giving various shades of blue
Genuine Defi triple set, oil, water temp and pressure
Pivot boost gauge
Twin AEM wideband AFR gauges
Boarder racing gauge hood
Kenwood head unit with four kenwood 5” speakers
Terrano chrome door handles
Leather 300zx logo handbrake boot
Leather 300zx logo shift boot
2000 model gear knob
Leather trimmed doorcards, glovebox, center console etc
PARTS NOT FITTED
RARE Final Flag polished throttle cable cover (1 actually have 2 of these and they don’t fit with the top feed rail L)
Nissan front strut brace (1 of only 2 in Aus), again doesn’t fit with the top feed rails
Twinz front lip V2 (to be fitted with splitter)
Bosch 1650cc injectors
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
