BNR32 Genuine C's Short Shifter - Used and comes complete.
Perfect working order, shift bush is fine.
A Discontinued item a while back now.
A more solid shift feeling and 30% shorter stroke to OEM
The best short shifter ever made for the GTR
$280 +postage
https://www.sau.com.au/forums/topic/451109-genuine-cs-short-shifter-bnr32/
Hi Richard,
I'll take this please since it includes the whole kit (ie plate, plastic insert, fingers that spread out from each corner)?
I'll need your details once more.
Kind Regards,
Terry
Besides being a shorter shift between gears Like around an inch or so to neutral. So maybe 2-3" between 1-2, 2-3, 3-4 etc..
It is firmer than the OEM (ie. not as loose feeling)
In a nutshell it is more direct feeling.
You don't miss gears and it stays in gears. It's not hard in to or out of gear but firmer and shorter.
Good for spirited drivers, driving enthusiasts and your race car driver. (I am getting lazy)
You don't throw it into gear, you move it into gear.
Think of paddling through air and paddling through water
If you have an issue with your GB or clutch I'd dissuade you from installing as it will amplify the issue.
Hope my explanation is helpful to all
Edit: Why would I let it go? Seemed a good idea at the time when I got home. I went OEM and the GTR feels less of a race car
although I am having second thoughts - hence why I haven't bumped it up
I checked the price on the Nismo shifters to price mine - Oh my son of rajab
Edited by Sinista32
Terry. When you get this. Can I loan the 2 round pieces on the left for the boys to use as reference to produce? I have the shifter. But am missing that 2 pieces.
*yawn*
The metal ring will be easy.
BUT the plastic washer will be the gotcha.
It's not simple by any means, it's unique underneath, although you may be able to simplify something (not sure).
Terry the 2 brass coloured "fingers" aren't in the box.
Will need to ask my Mech on Monday morning. I'll get back to you.
Terry, et al.
Unfortunately my C's Short shifter does not have the "brass fingers" (in the picture above), and did not have them in my GTR :glare:
Sorry for the hype and inconvenience. Withdrawn from selling.
Richard
Hey Des, I'm happy to send the metal ring up so you can replicate and then send mine back mate. Not a problem.
The plastic one I found out today is stock (OEM). needed for all shifters to mate up to the box. Your existing shifter will have one :)
Edit: Called Andrew @ Kudos. The plastic ring by itself is PN# 32875. Delivered to you would be under $20.
These metal rings are only for the short shifters. Best borrow mine for measurements.
Question for you.
Does your short shifter have the 2 brass coloured half moons or 4x allen key bolts and 4x nuts welded on square washers ?
Edited by Sinista32
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
