Hi everyone
My 350GT-8 cvt has a problem in gear shifting. This appears when I drive it for 40-50km. Once the problem start it will reduce the gears by itself and stay at 1st gear. When you keep the car switch off for couple of minutes and turn it back on it will drive for some time without any problem.
It has done 65000kms all together. Any helpful opinion would be highly appreciated.
https://www.sau.com.au/forums/topic/451233-350gt-8-cvt-help/
Probably a sensor fault.. you will likely need someone with a consult2 to figure out what is happening. They can be expensive to fix, and a lot of people have written off the car when they have had problems with this particular CVT.
  • Like 1
Please, PLEASE use the search function before starting a new thread - this has been covered DOZENS of times before. And as Sonicii said (and from my own experience) you have basically bought a lemon, and it is more than likely unfixable. These are VERY unreliable gearboxes, VERY expensive to troubleshoot and almost no-one in Australia has the expertise to fix them.
don't know if I would say they are particularly 'unreliable'. the problem comes when something goes wrong.. you struggle to find someone even willing to look at it.. then struggle to pay the repair bill when you do.
Hi mate, do you no anyone who can scan it and find the problem. I have been to few guys and with their tools they couldn't. If u know someone in Melbourne please let me know.
Thankz
Sorry, I don't know anyone in Melbourne. If you have any decent Nissan dealers, they should be able to check it for you.. otherwise, it might need someone with a consult2/3 clone. I don't think the basic OBD2 tools will access the TCM.
  • Like 1
How long have you had the car and how many kms have you done? Do you know the gear oil has ever been replaced? (Just curious) im doing a full flush next week, sump will come off so will have a quick look for any sensors
It is with me for nearly 3 years and I have done about 20000 kms. Just want to let you know one mechanic told me cvs shouldn't be flushed but I don't know it is for a fact.
people have different theories on fiddly gearboxes in a "if it aint broke dont fix/maintain it" sort of attitude. Personally, I think being proactive is a better way to go.
I've just imported my car with 100,000kms and the day after it gets rego'd im doing a full flush on the CVT.
  • 1 month later...
My car is fixed. It was a speed sensor fault. Guy who repaired it was an expert in these cars and if you r in Melbourne and wanting a good machanic contact him. Thanks everyone for their comments.
Nandi Autocare
Motor Engineers & Repairers - Keysborough, VIC
1 Futura Rd, Keysborough VIC 3173
03 9706 3444
  • 4 weeks later...
I have just finished conversion of my gt-8 to 6sp M/T. The only exsisting issue is to customise centre console which i have decided to buy an E-stopp parkbrake system which really is just providing hole for switch......I strongly believe that it is cost feasible to do conversion. Cvt oil is roughly just under $1000 every service interval of 20000km. A conversion kit is around $2000. If you are mechanically knowledged you shall find conversion of a medium factor. What a lot dont add to cost saving is that once M/T is installed you now have your vehicle tare weight under 1500kg ( with cvt = 1550KG). This in New South Wales equates to a yearly registration saving of around $140. I WAS A MECHANIC BACK IN 94' HOWEVER REALLY WOULD HAVE LIKED FOR A SHOP TO CONVERT FOR THE SIMPLICITY OF HAVING A HOIST. I WENT TO 40 DIFFERENT SHOPS AND ALL SAID NO EVEN THOUGH I WROTE STEP TO STEP INSTRUCTIONS. MODERN MECHANICS TODAY JUST WANT TO SERVICE, REALLY ARE YOU SURE YOU ARE MECHANIC!!!!!!!!!!!! FOR THOSE OUT THEIR CONSIDERING CONVERSION I AM HAPPY TO PROVIDE HELP WITH ANY KNOWLEDGE NEEDED DURING CONVERSION.....ADAM---0435729442....SYDNEY :yes:
Nandi Autocare
03 9706 3444
Glad it's sorted, thanks for sharing
Also Nissan factory service manual says cvt oil to be changed every 100,000kms. I don't know why you would think 20,000kms is acceptable for an oem box
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
