  • 1 month later...
Looks like I will be fitting the manifold and turbo to the 25 first. Engine is a long way a way with cost wise. Will be fitting over the next few weeks. Then getting it tuned. Want it done by the 24th of this month. Have a track day on the 26th.
  • 2 months later...
  • 6 months later...
Ok. So I have the bottom end back and about to bolt it together.
Just wanted to know what head gasket everyone uses in the rb30 25 neo builds. I know what thickness I need just not aure on witch one to use.
25 26 or 30.
Whats the best one?
Ok so have picked up the 30 head gasket and now trying to sort out the timing belt. Do you use the 25 tencher and idler or do you use the 30 ones. Also what brand belts is everyone using. Tried to find a t291 gates belt in racing series and gates Australia don't have them. I know people use the dayco std one but wanted to have something with better quality thats all.
You didn't read my answer.
Use any brand belt you want, it doesn't matter unless making huge power. I used a standard run of the mill Dayco belt.
Seeing as RB30 doesn't use an idler you may find it hard to use that. Like I said RB25/RB30 use the same tensioner bearing so it doesn't matter.
  • Like 1
Okay then I would buy the most expensive belt you can get, maybe get in contact with OS Giken and see what belt they used on their 26 strokers. Meanwhile everyone else will be over here using the inferior Dayco belt just fine.
Was speaking with a bloke the other day and he said that the top deck of the block needs a different finish for the cometic head gasket. Never used them before so don't know if this bloke was telling the truth or Tring to blow smoke up my arse.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
