This topic has probably been covered, but just want peoples opinions on best rim size on a r33 for looks as well as performance
I'm currently running 18 inch but I prob wouldn't go any larger.
You can reply if you have a different car but put you car next to your answer
Cheers :)
https://www.sau.com.au/forums/topic/451564-whats-your-wheel-size-r33/
Cheers :)
22s on a 33 rule ;)
This. Ben knows.
Something subtle like this perhaps.
http://projexuk.com/wheels/status/grinder_s815/black
Oh and I have a Falcon.
Edited by djr81
  • Like 2
