FULL ADD With Pictures http://www.gumtree.com.au/s-ad/mulgrave/cars-vans-utes/1992-nissan-gt-r-coupe/1064619524
Selling my pride and joy, a BNRR32 1992 R32 GTR in ORIGINAL condition.
When i was looking to buy one, i was after something with low kms and the least amount of modifications. I came across this and bought it, now priorities have changed and its time for someone else to show it the love.
PROS
1992 R32 GTR (late model) Tuned to 236kw @ 13psi (3/7/14) Have dyno Sheets
GENUINE 81xxx KMS (have papers)
Factory R32 GTR Wheels
ABS
Factory Turbos
R33 GTR gearbox
Factory Suspension
Factory Steering wheel (great condition)
Factory Front pipes + dump pipes
Factort front mount + piping
Hornet 433H JustCars compliant Alarm sytem + central locking ($520, also have receipts)
Body is VERY straight
Rails are Straight (no accident history, REVS checks are welcomed)
9months Registration left.
Turbosmart Boost Tee
HKS Super Drager 3.5' cat back (sounds REALLY nice)
Aftermarket Leather gearknob
Headunit and Speakers
Podfilter Intake Kit
Front and rear strut braces
CONS
Crack on front driver side plastic front bar, in the corner below headlight.
Fuel sender float is stuck (ive inspected it) So fuel gauge fluctuates (easy fix $50 part)
Sometimes (has its days) it has the usual RPM gauge fluctuations common on all R32 Models from dry solders.
Whiney throw out bearing.
$22500ono Ive listed everything that this car is about, its a great collectors car or sleeper, would like to see it go to a good home.If possible i prefer TXT messages as not always available for calls.
NO SWAPS! Not interested so dont bother. No test Pilots unless deposit is given.
GENUINE buyers only. Low ballers will be ignored.
https://www.sau.com.au/forums/topic/451646-vic-original-r32-gtr/
  • 3 weeks later...
BUMP, New Years change of mind looking to start a business/buy house.
Car back up for sale. COntact for info.
No major Rush.
Price Drop $21k
Car now has a addition of Trust front pipes, also front bar is being repaired atm.
0403485395
Edited by Cateans05
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
