Im installing 3 new gauges in my r34 triple cluster and wanted to know how people have actually wired them up( custom harnesses etc) and also for the llumination. A diagram would be awesome.
Just trying to figure out the best way to go about it :)
Cheers
https://www.sau.com.au/forums/topic/451657-aftermarket-gauge-wiring/
I just spliced into the cigarette lighter power (you can also splice into head unit power wire) and grounded it to the head unit or a bolt near the shifter. For the switch wire i spliced into the cigarette lighter wire when u turn on the parker lights.
Thanks mate thats the answer I was after. Cheers
Obviously running more gauges it would have got pretty messy (wiring wise) how did you get around this? Or did you basically run each individual wire to each point or?
These may seem stupid questions but tbh im more mechanically minded then electrically
I merged all of the similar wires together near the gauges by cable tying em together, then ran them all to the splice grouped together (so all power wires together, all ground wires together, and all switch wires together). It's probably not the "best" way to do it, but it's not as messy as I've had my electricals before. I kept them all grouped together with cable ties along the way from the gauges to the splice lol.
I'm not very electrically minded either, so i don't know what's best practice, but this has worked for me. I've only recently replaced my triple cluster as well.
With my gauge harness' they are to short to run all the way down to ciggy lighter so I will need to solder some more wire to them (hate soldering that 2-3mm wire haha)
Appreciate your replies man ☺
As i mentioned, you can run them to the wires of your head unit as well if they're too short.
But also, if you dont like soldering, i recommend using connectors. That's the route i've gone down nowdays when working with electrical components in the car lol. Less risk to eff up!
All good, happy to help! I sometimes have a hard time finding stuff that has been "covered numerous times before" also lol.
Yeh I hooked up my boost gauge last week and made a mess with the solder on that bloody little wire that comes with gauge..was a nightmare , in the end I managed to get it to all bond and taped it up and she works all sweet haha. Wanted to take a more professional looking approach this time tho :P even tho its not visable to other people it plays in the back of my mind haha.
Yeah I know..ive legit been searching for ages, nothing exactly what I was asking tho.
Haha I havent done that yet but it wouldnt suprise me if it happens in the future lol.
Okay sweet :) im sussing out a greddy filter relocation kit (no cooler) atm but not to sure
Possibly the best way to do it is to wire up the power and illumination wires through relays and then group them togethet to the gauges (depending on if the illum wire lights it up or just signals the gauge) then you save loading up the power/illumination circuits wherever you grabbed them from
Having said this, ive run mine directly to the wires with no problems. Think I just ran an extra fuse. I was just providing what would be my ideal setup, probably a relay powering a strip of accessory positives, a few illumination so you can just hook up what you want. But its a bit much for most setups
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
