Been a member on this forum for a number of years but haven't had a GTR in the garage for a few years and must admit, thought it would be a good 3-5 years until another (R34) was resting in there.
Sold my Liberty Tuned By STI and was in the market for a larger car, possibly a R36 VW wagon, until I saw initialdennis ridiculously clean VSpec up for sale. Seeing it was only 20mins away I thought I would go and check it out. As you all know, the GTR is a very emotional car and hearing that RB26 again and talking to Dennis about all the awesome work he and Chris from RacePace have done to it, it was pretty easy to talk myself into the purchase.
I can't wait to pick up the car next weekend and will begin my small personalisation program with the car. Doesn't need much at all to be honest, as you will see with the list of work been put into it. Here is little of whats been done to it but one of the most impressive things is the condition of the interior, especially dash and the original steering wheel- MINT!!
Engine:
Stock internals
Tomei sump baffles
HKS Oil cooler (Thermostat in sandwich plate)
Aftermarket Cam Gears
Garrett 2860-7 Turbos running 18psi boost
1000cc injectors
Walbro Fuel pump
Koyo 50mm alloy Radiator
Custom oil catch can behind battery
Apexi pods
Nismo AFM's
Oil Drain kit from head to sump
Power FC with HC
HKS Front Pipe
HKS Super Turbo 3.5" catback (nice sound)
metal cat converter
Exedy Button Clutch very drivable
310rwkw
Brakes & Suspension
Tein Super Streets
Cusco Front and Rear strut braces
Advan TC2 rims 17X9.5 wrapped in 235/40/17 hankook RS3's (nice stretch) no gutter rash at all.
braided brake and clutch lines
DBA 4000 Slotted Rotors all round
Adj caster rods front and rear
Camber adj upper arms
Interior & Exterior
Stock - no bubbles or cracks in dash
- no broken vents etc
driver seat has very small hole where they usually appear not too noticable
Defi Single Din Gauge measures Oil, Water Temp and Oil Pressure
Defi Boost gauge in driver side vent
Greddy Gear knob
Ganador Mirrors
No rust anywhere
Rear pods
I look forward to treating this car with the respect it deserves and hopefully turning this into an amazing street car!
Once its in my hands, I will post up some pics of how it currently looks and what my initial plans will be. Look forward to hearing everyone's thoughts on what they think I need to do to make this the best possible car I can.
Cheers!!
  • Like 1
https://www.sau.com.au/forums/topic/451693-new-owner-1993-r32-gtr-vspec/
Thanks Grant! Took it our for a little squirt last night and it is soooooo good! The main thing I love, is to get this car in immaculate condition, it only requires some cosmetic touch ups. Plans initially are to paint the wheels black, tint, get some of the paint work touched up, new driver's seat and possibly some new reg plates.
Other than that, for me there isn't much to do as I want this as a beautiful street car that I can drive to the track if I want to. I won't but its ready if I do;)
Going in for Tint on Wednesday, ready for the Hot Aussie Summer. Although it mainly only gets driven late arvo/early night time. Or early morning cruises so far:) Also have some plates coming in a few weeks for it - VSP3C1. Not too wanky I hope?!?!
Edited by glaze
Nice, I shall be your little brother then :)
Tint done, plates arrive soon. Nxt step, front & rear bar to be resprayed and touched up and to get a schmick set of black rims on this bad boy:)
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
