Hey guys,
I have just recently purchased my 89 GTR.....
I've had it for a couple of weeks & now i'm having starting issues - when i start it, its sometimes a little rough but fine when i drive, but if i try and start it while its warm or leave it idling the cat light comes on & the car shuts itself off- mind you its only idling for 30 seconds tops, battery light comes on & also the oil pressure goes right down & light comes on also.
I have absolutely not a clue whats causing it..
Any ideas?!
:wacko:
https://www.sau.com.au/forums/topic/451700-cat-temp-light/
But would that cause the car to just not turn on?
i am a bit confused as to why the battery light & oil pressure lights are coming on too & would it normally completely shut the car off?
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443288
It sounds like the car has a few issues which is a given given the car is 25 years old now so it is going to be a case of one thing at a time, the cat light is there to indicate the cat is dead so change it and go from there, cat convertor a are a service item and need to be changed periodicly, even worse if it still has the compliance cat
The oil pressure problem is a common one with 32s unfortunately which requires a seperate oil pressure test and then new sender unit
As for battery I had an issue like this year and years ago and it turned out to be the fusible link connection at the battery had corroded, I cut it off and put an eyelet back on and no more issue
  • Like 1
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443312
Yeah, it does have a few issues......
I think i might take it to a specialist.....
Anyone know any good ones in/around Wollongong
it would make sense though if the altenator was going dead - that wld explain the battery light & also the Cat/engine light - but oil pressure... not so sure...
The gentleman who i bought it from said he has recently replaced the battery... so it could be a start point
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443355
Hey guys,
... the oil pressure goes right down & light comes on also.
Any ideas?!
:wacko:
Have you checked the oil level in the sump? Have you changed the oil recently? (if not, maybe you should).
My experience is that the oil pressure light is usually not caused by a fault in the sender; it genuinely means that there is no oil pressure.
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443429
I can't remember now (it's been a while), but a flashing cat temp warning light means something is wrong with the ECU?
I haven't had a factory ECU since 2006 but iirc the cat light isn't connected to the ECU and it's the engine light flashing is an ECU fault but could be wrong
The oil pressure gauge in the RB26 in R32s playing up is realitively common, especially in the earlier ones, but is something that should be takin on the side of caution and tested properly before moving on
  • Like 1
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443444
I also had low oil pressure readings, changed the oil pressure sender with a new one and issue fixed.
Cat probe is a temperature sensor, when i first got my GTR the probe was not in, just coiled up under the car and the bunge plugged off.
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443457
XKLABA,
You are talking about the gauge, and, yes, they are problematic in that the sender sometimes fails or gives erratic signals.
I'm talking about the "Oh $HIT" light. I can't recall ever having the light come on even if the gauge is reading 0. Only time is when I genuinely have low oil, and therefore low, ie 0, oil pressure.
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443496
I can't remember, but last year when I put in a spare Nistune'd ECU in my car, a light was flashing (to indicate faulty ECU, sigh).
From Nistune:
Nistune Installation and Communications Diagnostics
Guide Page 18 of 28
6.2 Type 2 boards
Check section 4 if you can’t connect to your ECU.
Signs of limp mode on common ECUs:
1) R32 RB20DET, BNR32 RB26DETT
• ECU red LED and Exhaust Warning Light on dash will flash on / off
• Will not be able to connect to the ECU using consult
• Vehicle may start in limp mode but will not rev above 2000rpm without leaning out
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443505
I just checked the oil level - just to see....
Its on high, but it smells a bit like fuel (not sure if thats normal or not)
But the cat light/engine light doesnt flash - it stays on & the car wont start .... when it cut out on me whilst idling the other day it came on & the car turned off within a second... it was weird...
Im pretty sure ive got two issues going on atm...
Im going to do an oil pressure test & gut the cat at this stage... see whats going on...
Because mine is an earlier GTR im not sure if it has two sensors for the cat or just the one... a mate was saying if there is two i think you can disconnect it & bridge it somewhere ( i cant quite remember)
Ive got an Apexi Power FC here ready to go in if need be
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443678
Yeah i think at this stage im just going to gut the cat..... Ive got the boost pretty low so i doubt thats it.....
i honestly think ive got a few dramas atm.. which isnt unexpected, its an old car :)
But she is still my girl no less!
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443695
If you have fuel diluting the engine oil, you have a problem. I would strongly recommend an oil change immediately, then investigate why the oil is being contaminated by petrol (possibly a blowby problem).
And gutting the cat can be highly expensive - if you get caught with a gutted cat. Replace it if you think it's contributing to the problem.
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7444501
So, i have an update....
I was driving it to the place i was getting it looked at.... the light came on while i was driving & i lost all power... I changed down gears & pumped the accelorator, until i finally regained power & it made a bang sound... then i regained power & it hasnt boosted so hard since i have had it. ANDDD the light hasnt come back on since :) :)
Im de-gutting my cat this weekend, so i will see how it goes again....
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7449096
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
