I have a boot leak down the sides of the boot from the edge of the rear window down to the tail lights. along that seem on both sides there are multiple leaks. I've reduced it with silicone to seal the gaps but still get through a little bit. I've stopped about 95% of the water.
Just wondering who i can go to for a permanent fix instead of a temporary fix. I think i have diagnosed the problem. Should i go to a panel beater or smash repair? or do i get someone to weld it?
It's not a huge problem but i can't put the interior in my boot because it gets nasty and wet.
My problem is similar to this guys video. i did the same thing as him but with a different product
Any help will be appreciated, cheers.
Edited by SkylineR33RB25
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/
Pull the boot rubber off the boot opening, silicon the channel and then push it back on securely
Pull the tail lights out, silicon and put back in firmly
next day hop in the boot with a torch and get some one to spray water all over the back and check for leaks
Edit: Oh and seal all rust off from the oxygen if you have any
Edited by Sinista32
  • Like 1
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444434
It's not coming from the rubber seal around the boot it's coming from where the metal over lays
watch the video and look at where he is putting his sealant. and it's leaking from the top. up near the windscreen down to about half way . it's def not coming from the tail lights. it's drain perfect from there.
I highlighted in red where it's leak from in paint http://postimg.org/image/ylf6uk5az/
My question is who do i go to, to get it permanently fixed?
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444442
There is a great thread about this and has helped me and multiple other people.
The seal at the base of the window. The one with screws is a culprit. Pull it off and silicone.
The tail lights leak. Pull them out and reveal.
The bolt holes for the boot. There where it mounts to the guards leak as well. Silicone all those areas and You should have solved it.
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444449
That's where it's coming from highlighted in red ^^^^ click that link
It's coming from where the metal overlays. very small gaps in there. I can see it dripping from about half way so i don't think it's as high up as the base of the window
I can see it dripping into my boot when i fill the gutters up (the side of the boot) with water. and when i soak up the water from where i highlighted in the gutters it magically stops so it has to be coming from there.
Edited by PranK
Fixed underlined text.
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444456
My goodness. The seems will be deceiving. It will find one point of entry and then find the path of least resistance to the exit.
Oh btw I got quoted over 1 k to get the boot welded and painted.
I guarantee that if you chisel out the old filler you will find where it enters because there will be a rust spot.
The seems are not welded. They have this type of putty filler that ages and cracks
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444517
Can someone recommend a sealant.
I currently use Silastic. silicone rubber from autobarn in a 75g tube. I need something bigger like selleys. I'm going to disconnect my boot and do it properly.
Should i use selleys silicone? Would that be the best thing for the job?
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7449773
The product that I have used a million times in boats of both aluminium and fibreglass is Sikaflex. Its nutso once it sets.
Note, to get it to bond well, you'll need to really scuff the paintwork, or it just wont bond properly. Hit it with a wire brush on a drill or a dremel and then apply it.
Also, Keep it dry for a few days. Rain and storms this week, it you dont have a garage then just wait.
  • Like 1
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7449893
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
