Bosch Ev14. Aeroflow Rail. Freddy Ffp. I Could Butcher This
Hey. Got my parts. I can vision leaks thow.
They look nice
This green oring at injector nossle seems .5mm od too small but I could see it seating good when I bolt rail on putting pressure on it
The oring on the boss/adaptor seems to fat to fit into manifold, the adaptor fits snug. So Mabey a thinner oring will Winn this.
This blue oring fits squeaky tight into the rail, just how you would like it. Although, can u see the flange head looking bit on top of the injector? I can see that bottoming out on the injector rail cavity and not allowing the oring to be squashed under pressure. Although the plus side is injector would sit square to the rail. Is this right?
I was thinking Mabey grind the flange off or drill the hole In the rail bigger. Or Mabey that's the way it's spose to be?
put some lube on the O ring? I remember my boss was tight against the stock plenum but ok if i put some sillicon spray before trying to push it in
and no don't grind the top of the flange, mine's the same and I dont get any leaks
Remember there is no pressure really on the manifold o-ring so it doesnt need to be a super tight seal, the top o-ring holds the pressure so this is much more important to get sealed right. It should be reasonably tight in the rail.
My kit all seems normal. Adapters into the manifold are tightish and everything else feels good
The manifold adapters look ok. When the injector is pushed into the adapter it will seal down the bottom where the chamfer is
  • 1 year later...
Bit of a thread dig, but interested to see what people have found, or let people know of a potential issue......
So the manifold adpaters did fit fine in the standard manifold. However, my Greddy copy Manifold was a different story. the adapters are too large and won't fit inside the holes. My plan is to machine them down and use them, just interested to see if anyone else has found the same problem and how they got around it
BPP who supplied my fuel rail said its a known issue with the copy manifolds because they are never made exactly the same. So hopefully a bit of handy info for someone that will be in the same position
Shouldn't be too hard to machine down Callan, sorry I couldn't supply something that works.
I did know the Freddy manifolds are different, but they were larger from my experience, I just supplied a larger Oring for the adapter. Seems yours is smaller so as you say, quality control is shite on those Chinese plenums.
Not a problem mate, I appreciate your time anyway.
As long as Dad had a small enough bit to cut the o-ring grove a bit deeper, I'm not expecting any issues at all.
Its the first issue I've ever had with this manifold, I got it as part payment for some wheels I sold so at least I didn't pay for it[emoji14]
Have had one or two people say it is one of the better copies they have seen so can't be too bad
Ill let you know what size the holes are when I'm home on Friday/Saturday if your interested Scott? I was away so they just got a rough measurement by someone else the other day who didn't have verniers
They standard seals don't have to be forced in so I'm guessing there won't be much in it
Yep, I would appreciate it. These little changes can really cause problems with a top feed install. It should only be the larger part that needs .1mm removed, the Oring grove should be ok, you might just need a thinner Oring. Let me know if you have issues.
For those of you playing at home, measurements were as follows:
Manifold holes: 24.94mm
OD of injector adapters: 25.4mm
Must be made for a 25.5mm hole or so. I got the adapters machined down to 24.8mm and they worked a treat. Just had to try a different o-ring. Photo attatched:
  • Like 1
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
