Hey guys
First time posting but I have just finished rebuilding my rb25det with new stock piston rings, oem head gasket and had the head pressure tested and shaved. This engine is pretty much stock besides a fmc, regapped spark plugs and a boost controller set at 10psi.
Started the car and let it idol for about half an hr and everything seem to be going great so I decided to take it for a easy run through town and just out of town to make sure everything was going well which it was until I came back into town and pulled up at a round about and it started to sound like it was missing and then just stopped and now it still trys to turn over but no ignition. It sounds like it has no fuel but it has a full tank. Could it be that something has gone wrong and ecu has a error that is preventing it from starting.
Any and all advice accepted.
https://www.sau.com.au/forums/topic/451884-rb25det-rebuild/
I only idle it for so long because I needed to refit my front bar which has LED indicators that I had to rewire but otherwise I would have taken it straight out for a drive. There is a very slight leak at the back of the bell housing but not enough to cause any issue in that short of a time and I slightly overfilled the oil before it sat and idled but checked the oil again before going but when It stopped I checked the oil and it only just had a drop on the dip stick so I topped it up and tried to start it again with no success. I will definitely go through and check all those and fix the slight oil.
Is there anything else I should be looking for having just rebuilt it? everything sounded like it was running well and it idled perfectly before going out.
https://www.sau.com.au/forums/topic/451884-rb25det-rebuild/#findComment-7447218
Check everything
Check timing to see of its the same as you set it befote, if not could indicate the cam belt slipped.
Oil leak after a rebuild is a bad sign.
Your car didn't have to be running while you fitted the bar. Idling a new engine can cause the bores to glaze.
https://www.sau.com.au/forums/topic/451884-rb25det-rebuild/#findComment-7447238
So in having let it idle for so long there may be the chance that I have done something that may need me to basically rebuild it again? Coz if I have to rebuild it again I am thinking I will take it off the road and do a complete rebuild with forged internals but I would rather have it back on the road as I would have to buy another car in the mean time which is why I only used OEM Replacement parts to do this rebuild.
https://www.sau.com.au/forums/topic/451884-rb25det-rebuild/#findComment-7447249
So it might just take alittle longer for the rings to seat and at this point better of finding the problem and starting there? I also read somewhere that sometimes after a rebuild that the oil pump can fail mostly in the older cars is that a possiblity here or are the RB25DET oil pumps pretty good?
https://www.sau.com.au/forums/topic/451884-rb25det-rebuild/#findComment-7447261
Cmon man.
Look at your car. Don't worry about crazy shit.
Why do you think the pump would just die? What experience with engines do you actually have? Cos I can tell you that you would not for a split second confuse an engine that has stopped due to no oil pressure with an engine that's out of fuel if you had a clue.
https://www.sau.com.au/forums/topic/451884-rb25det-rebuild/#findComment-7447281
Bit of a worry if you started out with full oil and then had none. Plugs probably fouled on so much oil going into combustion chamber. Have you tried new plugs then restart ? As stated, fuel & ignition. Check compression, oil in turbo intake. Oil had to go somewhere. even the exhaust would have oil in it to lose that much so quickly.
https://www.sau.com.au/forums/topic/451884-rb25det-rebuild/#findComment-7447462
Yep, I missed the "only a drop of oil" bit.
Wow.
Wow
Wow.
That's a huge leak.
I'm still confused how you can mistake dead engine due to no oil with no fuel? Or how you have such a massive leak. Or not know how to run in an engine.
Good luck with it. Good on you for having a go, but as you may have learnt whilst an engine is simple, there's a lot that can go wrong.
Take your time and figure out what has happened here.
https://www.sau.com.au/forums/topic/451884-rb25det-rebuild/#findComment-7447496
OP had a drop of oil on dipstick - not an empty sump but still a worry. But probably not the cause of non starting.
How long was your rebuild? Could have stale fuel or crap in tank. Take out your fuel filter and turn on the ignition - plenty of fuel? Replace with a new filter and cut the old one open to have a look. Like they say - go back to basics - check the CAS - look for spark, injectors clicking - pull the plugs to see if they are oiled up and clean or replace. Double check the cam timing and cam belt.
https://www.sau.com.au/forums/topic/451884-rb25det-rebuild/#findComment-7447528
Take the CAS out and check you havn't actually broke the shaft, if its not aligned properly it shears off, it would start missing badly until it sheared off then, nothing , as OP described.
Also as said, check the timing marks line up incase the belt has come loose, from incorrect torque settings on the tensioners and crank pulley bolt.
Edited by AngryRB
https://www.sau.com.au/forums/topic/451884-rb25det-rebuild/#findComment-7447543
Hey Guys,
So just thought I would let you know where I am at with it. I have gone through and checked the CAS which is all good, timing belt is still spot on, checked the fuel pump by removing the pipe after the fuel filter and turning it to on and plenty of fuel coming through, so I did all this while waiting for my ecutalk cable to arrive and when it did I plugged in and it came up with error code 21 - Ignition error so after this I continued to pulling all my spark plugs and they were all white on the tips which would mean that they had fouled so I bought a new set of spark plugs and have replaced them all and as I reassembled it I checked that all my coilpacks were all good replaced the cover and at this point I still had the car in the on position from when I was using my laptop and didnt think twice to switch it off but as I was replacing the ignitor module I plugged it all in and sat it on the cover so I could grab the bolts and socket I picked it and found that it was burning hot. So this has lead me to believe that this module is fried and is the cause of my issues so I have bought a replacement and just waiting for it to arrive so I did some research as to why this mights have happened and found that it can happen if the earth is not earthed properly so I checked my earth and found that I have somehow placed it under the rocker cover screw at the back so I have moved it to under the last bolt at the back that holds the plate for the coilpacks.
Is this what caused my issues or is it still only part of the issue? Thoughts?
Thanks
https://www.sau.com.au/forums/topic/451884-rb25det-rebuild/#findComment-7453459
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
