So i rigged up this simple, free incar mount for my gopro today and figured it was worth sharing.
You will need:
A drill;
screwdrivers;
the plastic base that your gopro came attached to in the box;
About 20minutes
Remove your interior light fitting. Grab the black base that your gopro was attached to in the box. Mark and drill two holes in the appropriate location. Mount it to the roof in place of the interior light. The plastic is quite soft so I suggest a couple of big washers and dont overtighten. Use the supplied mounts and arms to position the camera.
  • Like 6
https://www.sau.com.au/forums/topic/451916-diy-gopro-mount/
Nice Idea. I've been thinking of doing that one myself. You might want to buy an extra long extension off ebay to get it down a bit, but not too far, the spot metering gets a bit confused if there is too much overglare from direct sunlight.
I'll be doing something similar soon. Thanks for posting it up.
https://www.sau.com.au/forums/topic/451916-diy-gopro-mount/#findComment-7448578
  • 1 month later...
So, I finally got around to fabricating a mount. I tried the plastic like you but didnt like the wobble cause the base isn't as snug as the mounts that come with the go pro.
I made an aluminium base plate from a bit of angle and cut one side of angle down so it tucks up inside the headliner space. I then moutedan 8 inch magic arm. Will be testing this at some upcomeing motorsport event.
this is the view
  • Like 1
https://www.sau.com.au/forums/topic/451916-diy-gopro-mount/#findComment-7489053
yeah the plastic base is quite soft so Im unsure how it will go with vibration etc. I've only done a few short road tests so far and its been fine but I'm going to try it out at the track end of this month and see how it goes. How did you attach the magic arm to the baseplate?
https://www.sau.com.au/forums/topic/451916-diy-gopro-mount/#findComment-7490998
This video will give you an idea. The base plate still moves around a little so I might put an extra two screws in to make it more secure.
I had another video that had a bit more vibration in it. Mind you, I use the curbs and on semi's you'll see the G-meter holding 2G's for over a full second.
https://www.sau.com.au/forums/topic/451916-diy-gopro-mount/#findComment-7496403
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
