Dunno about that, most of the 86's I see have stupidly sized wheels, lowered to the bump stops with all the camber for hard parking meets.
Then the ones that try to drive fast with TC/DSC off end up as parted out wrecks at Import Monster
  • Like 1
^I'm not disputing that, in fact, I agree. Most people destroy the awesome handling of our cars.
I'm just pointing out that a standard Excel wouldn't out-handle, nor pull away from a standard 86 in a straight line. One is an older, FWD family car which accidentally happened to handle well. The other is a newer, RWD, proper sports car with a lot of R&D that went into the handling of the car. It might be a little bit slow, but it's not that slow. And in the hands of a good driver (ie. you) they do wonderful things.
lol relax guys, but yeah. Honestly, it was no doubt a crap driver but I did killed him in the 2 hairpins before he did a loser flyby on the straights.
"It don't matter if you win by an inch or a mile. Winning's winning." :P
But since then, I've been really curious how my excel on lowered king springs actually compares to the 86.
I was hoping to have the Skyline back on the road so I can come and watch and help out. But it's looking like it's not going to happen. :unsure:
Do you think they'll let me plug the LEAF into an outlet for a few hours to top me up so I can get home afterwards? :blush:
Buy a petrol generator from bunnings and strap it to the roof... Unlimited range!
You might as well just drive a petrol vehicle then since you're still using petrol.... what you might want to do is strap some solar panels on the roof. Unlimited range anyone?
Hey guys,
I've entered and paid for this event but I'm going to have to pull out as my car needs it's mechanical gremlins from Phillip Island sorted out once and for all before Round 2 at Winton so it will be off the road until then.
How do we go about getting someone else to fill my spot for this? Also what happens with the entry fee that I've paid? I'll probably still come along on the day for a while to spectate...
Hey guys,
Same here
Do I withdraw via this post, email motorsport or via the entry site?
Aim is to still free up some time to assist.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
