Yes it can handle it. For a while. But they're not really strong enough and will die an early death.
Any RB25DET gearbox will do. So that's R33 or R34. 33 is push clutch, 34 is pull clutch. That's about the only effective difference.
By the way, don't do this. Sell NA to P plater. Buy turbo car. Much less hassle unless you have spent heaps of $$ on the car already. You need brakes and an LSD.
By the way. This has been covered a trillion times before. Is searchable topic.
https://www.sau.com.au/forums/topic/452760-engine-swap/#findComment-7461928
Thank you and sorry I just joined. Yes I've spent quite a bit on it already so im a bit reluctant to sell. I bought a turbo 4dr for 2k so I'll be swapping everything from brakes and lsd but it's auto so I will be selling that ( car was stolen and smashed ) . Thanks again and sorry for my newbie post
https://www.sau.com.au/forums/topic/452760-engine-swap/#findComment-7461940
I have been through this, would still advise not to, unless you are willing to swap literally every part. Not just the things you were talking about, youd be surprised how much other little differences there are, brackets etc, wiring etc that exist.
You will end up swapping everything except the interior and body panels :P
https://www.sau.com.au/forums/topic/452760-engine-swap/#findComment-7463059
meh, a big job makes you enjoy your work once it's finished. and if you love the car there's no way around it
the right amount of work does this. which I would say falls into the category of owning and modifying and maintaining a GTST/GTT etc.
This sort of thing (n/a - turbo etc etc) falls into the category of ultra tedious, more time working on it than driving it, endless gremlin pursuits and troubleshooting, more money than expected, and in the end its a registration/defect sticker abortion worth fk all.
I cant ever see this being worth it.
Edited by jjman
https://www.sau.com.au/forums/topic/452760-engine-swap/#findComment-7464518
lol then wonder what category what ive done with my car would fall into lol
https://www.sau.com.au/forums/topic/452760-engine-swap/#findComment-7464551
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
