Well I am looking forward to this season. Hopefully Porsche will be a little stronger but very keen to see what Nissan-Nismo have in store.
Also planning on going back to Le Mans this year. Just have to see how finances go as I may end up going to Japanese round instead later in the year
The first disappointment of 2015 are the spy pics of the Nissan GTR LM. Farking UGLY! :(
Front engined?
https://www.sau.com.au/forums/topic/452932-wec-le-mans-2015/
Front engined?
wow. talk about being beaten within an inch of it's life with the ugly stick.
Not the prettiest thing
And sorry Nissan. Call me old fashioned but I nevber want to see a FWD car EVER WIN LE MANS!
Sorry Nissan. I hope it crashes and farking BURNS!
A FWD "GTR"? Now I've seen everything.
Here's hoping it's all in the name of development for the R36.
Nissan...I suppose you give your racing operations to the Poms you get awesome looking cars like this
Leave it up to the Nissan folk in Japan and you get their 2015 abomination
I have been doing some research for another holiday this year to include Le Mans again and after seeing this....um it certainly takes away the excitement I had for Nissan joining.
Oh well, still have the main game and that is the 3 car Porsche team.
I look at the Nissan range of cars now and just sigh. Nothing in their line up appeals to me. Their GTR race program was at least cool, even though they struggle in GT3 form they sounded and were awesome n GT1 guise up against the Maseratis, Ford GT, Lambos, Astons etc etc..
Oh well. At least I still have the 919 and the C7 Vette in GT :)
Apparently the electric side can send power the rear wheels?
Anyway, I reckon it's cool, different, "innovative" (some text here).
yeh, oddly if they chose to they can through about 560 diffs and shafts :)
I have wondered why a team has not done a backwards 919 with front engine and electric motors on rear wheels where you can really vector the torque for traction
I agree, much easier to throw an electric motor or two on the rear axles.
http://www.topgear.com/uk/car-news/nissan-gt-r-le-mans-car-2015-02-02
TG are claiming that the GTR LM has a 700hp electric motor in the back to boot giving it 1250hp when both are used.
If the car proves reliable it is definitely in the chance.
There was a time when Brendon Hartley was the golden boy of the Red Bull Young Driver Program. He got dumped when he simply couldn't consistently get the results to win a championship.
So interesting that Red Bull have stated sponsoring him again this year. So that puts two drivers in Porsche Car 20 as wearing Red Bull sponsorship
It's the seppos you need to blame. But I think it's cool to see some actual innovation in concept, packaging, drive configuration and aero instead of the usual cookie cutter "prototype" cars. Its a radical concept and the most interesting thing to come along in prototypes for a generation and all people can say is "it's not pretty" and "fwd is gay" - when it's awd anyway.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
